    Can't Upgrade to 7.2.2
    cant upgrade 7.2.2
    • Grahf 0
      Grahf 0 last edited by
      Trying to upgrade to 7.2.2 reloaded from 7.1.1 reloaded. It will start to download the upgrade, get about 3/4 of the way through the status bar, then say "Error downloading recalbox 7.2.2-Reloaded...Please retry later!"
      davidb2111 Zing 2 Replies Last reply Reply Quote 0
      • davidb2111
        davidb2111 Staff @Grahf 0 last edited by
        Hi @grahf-0
        Can you put the SD card to a PC and check the free space of the partition called "RECALBOX".
        You must have at least 1Gb free.
        If you have enough space, go to the manager (usually http://recalbox or http://recalbox.local), click on "logs" -> select "/var/log/messages" and click Check.
        Paste here the log file.
        David
        Grahf 0 2 Replies Last reply Reply Quote 0
          Zing Global moderator Translator @Grahf 0 last edited by
          @grahf-0 Watch this video (enable subtitles):
          https://www.youtube.com/watch?v=gPwtCNIeFmg&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=13&ab_channel=Recalbox
          • Grahf 0
            Grahf 0 @davidb2111 last edited by
            @davidb2111
            I only have 825.4MB free on the recalbox partition. Is there anything I can delete on that partition. Like the update folder. That folder alone is over 850MB. Or do I need to resize the partition?
            • Grahf 0
              @davidb2111
              I removed the update folder and the update worked. Thank you.
              • Locked by  davidb2111 davidb2111
