    Rotate screen and negative overscan
    rotate negative overscan
    • i_am_millski
      i_am_millski last edited by
      Is it possible to rotate the screen to be more suitable for vertically mounted screens? Also I've used overscan in config.txt to stop my output running off the edge of my screen, but I now have a letterbox effect (about 24 pixels top and bottom of black bar). All my overscan settings are at "xxx_overscan=0" - can I set top_overscan=-24 (-24) or something similar?   This forum really needs a search function 😕
      Geek, car nut, gamer, photographer and I enjoy pastries
      • digitaLumberjack
        Hi, see https://www.raspberrypi.org/documentation/configuration/config-txt.md for rotation and overscan, you can do everything you asked. Even search on the forum : http://blog.recalbox.com/?s=this+forum+really+needs+a+search (top right on your screen)
        • i_am_millski
          Thanks digitalLumberjack, just what I needed 🙂 Thought that search button was for wordpress, not this site specifically, d'oh! Edit: Is there a way to scale the emulationstation menu better for a vertical setup?
          • i_am_millski
            b*mp Any help with the emulationstation vertical menu?
