    Problem performance & controller mapping with N64 Retroarch
    Mandos/GPIO/Codificador USB
    performance mapping retroarch
    • Benzitor
      Benzitor last edited by
      Hi,
      Since i updated to 7.2.2, i hve 2 problems with the n64. First one, only 2 emulators run the games ( Mupen64 next and Parallel64 )
      But Mupen64 is extremely laggy and the sound is impossible to run smooth anymore, even on a pi4 with 4gb and overclocked at 2000...
      Then i switched to Parallel64, and even with all the graphical glitch, the games run smooth...BUUUUT, i still cannot save the controller mapping to get a simple Dpad of my USB Snes controller to Map the stick. Everytime i save, it doesn't work anymore after quit.
      I tried the override, the specific game config, the system config, the configuration setup on new file.... NOTHING WORKS
      In the end, the initial Retroarch setup takes over and i cannot remap ( even remap doesn't work actually )
      This is really annoying and frustrating because before you change the Emulator on the 7,2,2, all was fine.
        Zing Global moderator Translator @Benzitor last edited by
        @benzitor Please use the forum's search tool and check if one of the many posts talking about N64 helps you:
        https://forum.recalbox.com/search?term=n64&in=titlesposts&matchWords=all&sortBy=topic.lastposttime&sortDirection=desc&showAs=posts&page=1
