    XBOX one USB connected to Raspberry pi 3 B+
    GamePad/GPIO/USB encoder
    xbox usb connected
    • T-Nieblas
      T-Nieblas last edited by
      Hi all I´m new here
      Currently I'm working in a portable arcade console project, the problem that I'm currently have is when I turn off and turn on the raspberry the gamepad does not work, I have to unplug and plug the Gamepad USB cable and gamepad works well. Every time I turn off and turn on the raspberry I have to unplug and plug on USB cable. Recalbox 7.2.2is installed. Anybody have the solution to this terrible problem?
      Thanks all
        Zing Global moderator Translator @T-Nieblas last edited by
        @t-nieblas I don't have this control so I can't test it, but see if any of these topics help you:
        • https://forum.recalbox.com/topic/24099/xbox-one-controller-1708-en-bluetooth-non-fonctionnel
        • https://forum.recalbox.com/topic/23362/recalbox-controller-problems
        • https://forum.recalbox.com/topic/23027/probleme-de-mapping-manette-xbox-one
        • https://forum.recalbox.com/topic/24962/x-arcade-dual-stick (I know this topic does not talk about the same model of joystick, but read and you will understand that the suggestions presented here can also be used for your problem)
        T-Nieblas 1 Reply Last reply Reply Quote 0
        • T-Nieblas
          T-Nieblas @Zing last edited by
          @zing thanks for your contribution. I already make it work. The thing is that I remove the battery from the Xbox controller. Once I turn off and turn on the RP, The controller works. I'm not sure why but I think that the Bluetooth or any system inside the Xbox controller was searching first to connect instead of connect directly to the raspberry through usb
