    How to hide the mouse cursor recalbox X86_64
    GamePad/GPIO/USB encoder
    hide mouse cursor recalbox x8664
    • Dantemax
      Dantemax last edited by
      Hi everybody,
      I have the recalbox 7.2.2 for X86_64 installed in my arcadecab with a trackball.
      The trackball works fine but when I play a game like Alien the gun.
      I have the visor but also the mouse cursor.
      With Arkanoid I can move the 'pad' with the trackball but it also display the mouse cursor.
      Can you please tell me how to disable the mouse cursor ?
      Thank you for your help.
      Max
        Zing Global moderator Translator @Dantemax last edited by
        @dantemax See if this helps:
        https://www.reddit.com/r/RetroArch/comments/mtyvyy/how_to_disable_mouse_pointer_on_screen/
        • Dantemax
          @zing
          Hello,
          Thank you for the reply.
          I have read the topic in reddit but I have not the option "pointer type".
          I have read that we can add the following command -> input_overlay_show_mouse_cursor = "false"
          but in which file ?
          Thanks again.
          Best regards,
          Max
            @dantemax Test by creating a Configuration overload file for a specific game:
            • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload
            • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload/retroarch-overloads
            Dantemax 1 Reply Last reply Reply Quote 0
            • Dantemax
              Dantemax @Zing last edited by
              @zing
              Hello,
              Sorry for the late reply.
              Thanks to the documentation and after some research from my side, I have put the command in the file :
              recalbox/share/system/configs/retroarch/retroarchcustom.cfg
              Now it is ok.
              thanks again for your help 😉
              Max
