    Problem USB encoder Recalbox x_64
    GamePad/GPIO/USB encoder
    usb encoder recalbox x64
    • Dantemax
      Dantemax last edited by
      hello,
      I have a arcadecab and I want to modify it and place a Recalbox PC.
      I have installed the recalbox 7.2.2 on a PC_X64 and I have a problem with my joystick panel.
      I have one USB controller MR-P022 installed in my arcadecab with a panel for 2 players.
      Recalbox recognize one MICREAL USB Controller but not the second one.
      Then I have tried with a Raspeberry PI3 B+, I have add the command line "usbhid.quirks=0x0314:0x0324:0x040" in the CMDLINE.TXT and it worked. The 2 joysticks were recognized.
      Is there a way to do the same with the X_64 version ?
      I search in internet and various forum but I do not find the solution for the x_64 version.
      thanks for your help.
      B.R.
      Max
      Dantemax 1 Reply Last reply Reply Quote 0
      • Dantemax
        Dantemax @Dantemax last edited by
        @dantemax said in Problem USB encoder Recalbox x_64:
        hello,
        here is the log : https://transfer.sh/1m7GfR9/recalbox-support-d49f1e26-651b-daba-0e69-26efc9e19c3c.tar.gz
        BR
        Max
          Zing Global moderator Translator @Dantemax last edited by
          @dantemax Sorry, I'm not a developer, and I'm not sure how to solve this problem, I can't test it on the PC version right now, but searching a little bit I found this old issue:
          https://gitlab.com/recalbox/recalbox/-/issues/519
          As you can see, the user mentions that it is possible to edit the "usbhid.conf" file.
          Searching here on the forum, I found this topic:
          https://forum.recalbox.com/topic/17128/dualshock-2-manque-3-boutons
          Check if this helps, and give feedback.
          • Dantemax
            hello,
            thank you for the reply.
            I have found the solution in this topic :
            https://forum.recalbox.com/topic/11632/encodeur-micreal-dual-arcade-non-reconnu?_=1629830593023
            best regards 😉
            Max
