    7.2.2 PI 4 does not show image on tv
    7.2.2 does show
    • Clay
      Clay last edited by
      Hi!,
      The problem is the following, when I connect to my 24" monitor it works without problems, but when I connect it to my 42" 4k TV it does not show an image
      connected to my tv:
      I tried commenting this line and it didn't work:
      ;system.es.videomode = CEA 4 HDMI
      any suggestion?
        Zing Global moderator Translator @Clay last edited by
        @clay Test with the other HDMI port, or make sure you don't have a cable or TV problem, the tvservice command should have recognized your TV, it doesn't seem to be a problem with Recalbox.
        • KamilCieplak
          KamilCieplak last edited by
          Find on your recalbox sd card file named "recalbox-user-config" and edit lines:
          uncomment to force a specific HDMI mode (this will force VGA)
          hdmi_group=1
          hdmi_mode=16
          It works to me.
