    [Question] Having hotkey & Fast forward on the same button
    Emulator Arcade/PC/Console
    [question] having hotkey forward same button
    • Zehanort
      Zehanort last edited by
      Hi, i want to speed up the battle in pokemon or other games, i know of the Hotkey + right function, but if it is active i cant perform any other actions like controlling the menu in the battle. Thank you
        Zing Global moderator Translator @Zehanort last edited by
        @zehanort You cannot set hotkey & Fast forward on the same button, the most you can do is set the hotkey to a button other than select (not recommended, but possible), and set fast forward to another button.
        Example:
        Hotkey = R2
        Fast forward = L2
        You can make a Configuration overload file for this, for an entire console, or, just for a game, read the documentation:
        • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload
        • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload/retroarch-overloads
        Use the survey tool and you will notice that some users here on the forum have already successfully done configuration overload (not for this purpose).
