    Emulation Station / ES won't start / boot
    station wont start boot
    4302
    • neo207
      neo207 last edited by
      Hello ES won't boot anymore. Haven't added new roms or changed anything. any help?
      the ES-log file:
      [2021/07/25 11:24:10.875] (INFO ) : [StaticLifeCycleControler] RecalboxConf instance created.
      [2021/07/25 11:24:10.875] (INFO ) : [StaticLifeCycleControler] NotificationManager instance created.
      [2021/07/25 11:24:10.876] (INFO ) : [MainRunner] EmulationStation - v 7.2.2-Reloaded, built Jun 17 2021 - 23:26:32
      [2021/07/25 11:24:10.877] (WARN!) : [Locale] /usr/bin/locale/lang/de_DE/LC_MESSAGES/emulationstation2.mo not found.
      [2021/07/25 11:24:10.877] (WARN!) : [Locale] /usr/bin/locale/lang/de/LC_MESSAGES/emulationstation2.mo not found.
      [2021/07/25 11:24:10.877] (WARN!) : [Locale] /usr/share/locale/de_DE/LC_MESSAGES/emulationstation2.mo not found.
      [2021/07/25 11:24:10.877] (INFO ) : [Locale] Using /usr/share/locale/de/LC_MESSAGES/emulationstation2.mo
      [2021/07/25 11:24:10.878] (INFO ) : [StaticLifeCycleControler] Board instance created.
      [2021/07/25 11:24:10.878] (INFO ) : [Hardware] Hardware BCM2711
      [2021/07/25 11:24:10.878] (INFO ) : [Hardware] Pi revision c03114
      [2021/07/25 11:24:10.878] (INFO ) : [Hardware] Default hardware interface created.
      [2021/07/25 11:24:10.878] (INFO ) : [StaticLifeCycleControler] AudioController instance created.
      [2021/07/25 11:24:10.885] (INFO ) : [PulseAudio] Connected to Server.
      [2021/07/25 11:24:10.885] (INFO ) : [PulseAudio] Enumerating Cards.
      Here it stops while my other rasp4 with same configuration works fine and has more info in the log file.
        Zing Global moderator Translator @neo207 last edited by
        @neo207 Read This:
        https://forum.recalbox.com/topic/24654/recalbox-splash-screen-freezes/2
        neo207 1 Reply Last reply Reply Quote 0
        • neo207
          neo207 @Zing last edited by
          @zing First of all - thank you for your reply but you are practically telling me that this is a problem of the SD Card... so i tried to repair etc... no change.
          So I bought a new SD Card.
          Fresh install of Recalbox. Scraped my movies and TV Series in Kodi. Added some roms and scraped them. Restart worked, so I shut down everything at night and tried the next day.
          ES or Kodi doesn't start at all again. I get the splash screen (without sound) and then It stops at the black screen with the pacman ghosts...
          So before I throw my raspberri pi 4 against a wall (or switch to retropie or something else)... could you please tell me what is going wrong here (as far as you can)?!
          kind regards.
            Zing Global moderator Translator @neo207 last edited by Zing
            @neo207 Can you start ES from this screen with the procedure I suggested?
            2 - Or, check if the problem is not just with the emulationstation:
            • Start your Rpi4 until you reach this screen
            • on a computer or smartphone, open a browser (could be Chrome or Firefox, etc.)
            • in your browser's address bar, type:
              http://recalbox/help
            • This will open the Recalbox manager.
            • There is a part with Stop and Restart EmulationStation options
            • Click on Restart ES, and wait a few seconds
            I notice you have a history of KODI issues, isn't that any kodi manipulation that's causing this?
            • neo207
              @zing first of all, thank you for your help/time. I appreciate that.
              I tried everything you mentioned and ended up trying another OS (don't want to advertise others than Recalbox so no name as long as you don't ask).
              I have zero issues with games, although i prefer recalbox in general. I still use recalbox for my arcade machine but will stick to the other OS for the living room, where we mainly use the Pi for KODI.
              and a HUGE SURPRISE... the CEC Adapter works fine now with the other OS. I never managed to get my remote working with KODI/Raspberry Pi4/Recalbox. But now, it works out of the box, without any tweaks. just plug and play.
              So I am happy with Recalbox in my arcade cabinet and another OS in the living room for KODI.
              kind regards.
                @neo207
                CEC Adapter
                The developers are working on it, hopefully when the next version is released (no prediction) it will be resolved and you can get back to using Recalbox.
                • MisterB 0
                  MisterB 0 last edited by
                  Hello, i have actually the same problem each time i launch the command "Restart system" from Emulation Station.
                  From Cold start, ES starts normally, then each time i try to reboot recalbox, the issue occurs.
                  So i start a new fresh install on a new sd card but problem is still the same 😞
                  config :
                  • RecalBox 7.2.2 reloaded
                  • Raspberry 4b 2Go
                  • SD Card 16GB / 256 GB
                  • USB Encoders, Sanwa Joysticks
                    Zing Global moderator Translator @MisterB 0 last edited by
                    @misterb-0 Please, don't SPAM:
                    https://forum.recalbox.com/topic/24943/es-freeze-dont-start-after-warm-reboot
