    Raspberry Pi 4 won't shut down - trying /dev/input/eventX
    wont shut down trying devinputeventx
    1928
    • sylasebas
      sylasebas last edited by
      Hello guys
      I was wondering if you might be able to help me. I'm using a Raspberry Pi 4 together with a RetroFlag Nespi 4 case. In order to use the power button the case, I changed the recalbox.conf according to this post and remove the ; from line 14
      # System Variable
      ;system.power.switch=WITTYPI             # http://www.uugear.com/witty-pi-realtime-clock-power-management-for-raspberry-pi
      ;system.power.switch=PIN356PUSHRESET     # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
      it seems to work as it starts to shut down, the LED is blinking but it doesn't power off.
      The same happened before using the power button by just shutting Recalbox down via UI.
      in the console, it shows the following message over and over again:
      Trying /dev/input/event0
      Trying /dev/input/event1
      Trying /dev/input/event2
      Trying /dev/input/event3
      Trying /dev/input/event4
      Trying /dev/input/event5
      Trying /dev/input/event6
      Trying /dev/input/event7
      Not found.
      Retrying in 30s.
      does anyone have any idea on how to solve this issue?
      Thanks so much and best regards, Sylas
      • sylasebas
        @sylasebas
        here are some more of the messages before the trying events ...
        umount: can't umount /recalbox/share/bootvideos: Transport endpoint is not connected
        umount: can't umount /recalbox/share/system/.config/retroarch/assets: Transport endpoint is not connected
        umount: tmpfs busy - remounted read-only
        umount: can't remount tmpfs read-only
        umount: /dev/mmcblk0p1 busy - remounted read-only
        umount: none busy - remounted read-only
        umount: sysfs busy - remounted read-only
        Not found.
        Retrying in 30s.
          Zing Global moderator Translator @sylasebas last edited by
          @sylasebas
          • https://forum.recalbox.com/topic/24395/recalbox-v7-2-1-nespi4case-installation-tutorial
          • sylasebas
            thank you so much, that did it
            I searched specifically the error message, didn't think too much about the case
            • CoolCat64
              CoolCat64 last edited by
              I have a similar problem, but I do not have the NesPi4 case. I have a Pi 400, which is a stand-alone keyboard/case model that I have not modified from the manufacturer.
              My setup is:
              • Recalbox 7.3-Beta10
              • Raspberry Pi 400
              • Xbox One Series X Controller (QAU-00021) connected via USB
              When pressing F4 to close Emulation Station and then ALT-F2 to access the terminal, the following is shown ad infinitum:
              Not found.
              Retrying in 30s.
              No prompt comes up to enter a username or password, so I assume that it is impossible to access the terminal locally?
              Fortunately, I do have networking enabled and SSH turned on. I logged in remotely via SSH.
              After rebooting via SSH, I was able to access the terminal locally again. Any ideas of what might be causing this?
                Zing Global moderator Translator @CoolCat64 last edited by Zing
                @coolcat64
                Recalbox 7.3-Beta10
                BETA is only for BETA testers, because they know what they're testing and they know that BETA versions have a lot of bugs because it's a test version.
                Use the latest official version if you want support.
                CoolCat64 1 Reply Last reply Reply Quote 0
                • CoolCat64
                  CoolCat64 @Zing last edited by
                  @zing I did also experience this same problem twice when I was on 7.2.2 Reloaded. Same hardware setup.
                  It seems like the problem is intermittent for me. I don't know how to reproduce it. I could go back to 7.2.2 and wait for it to happen, but I would need to have some bread crumbs for what to investigate.
                    @coolcat64
                    So your problem has no direct relation to this one, you should open a new thread.
                    I don't believe it's a Recalbox bug, it seems to be a problem exclusively for you, as I don't see reports from other users.
                    Use the latest official version, and the default theme and then check if it happens again, if it happens, open a new thread with as much information as possible.
                    Also test with another joystick if possible, intermittent errors can be caused by some bad hardware contact for example (I'm not saying this is the case, but it's a possibility).
