    Samba settings reset after shutdown
    samba settings reset
    • levy82
      levy82 last edited by
      Hello,
      I have facing issues with samba server settings and i want to ask your help.
      The problem is when i want to access the samba share folder (under linux mint) i got this error "Failed to retrieve share list from server".
      The problem is solved by adding the 2 lines below to smb.conf file.
      client min protocol = NT1
      server min protocol = NT1
      My problem is that the smb.conf file always returns it's original state (and the added lines disappears) after i shutdown the PC and start it again. My Recalbox setup is a PC setup on HDD.
      What i need to do to make the changes permanent?
      Thank you, and sorry for my poor english.
        Zing Global moderator Translator @levy82 last edited by
        @levy82 I'm not sure you're editing the right file, not even the right way, see if that doesn't help you:
        https://forum.recalbox.com/topic/21821/smb-not-working-in-recalbox-v7-0
        If it doesn't work, you need to give more information so someone can help you:
        • What is your version of Recalbox (say version, don't say "latest")?
        • Did you build your Recalbox yourself, or did you download a ready-made image from the internet, or did you buy everything ready-made?
        • Did this setting never work, or did it stop working after a specific time?
        • How are you turning off your Recalbox? (It is necessary to turn off securely via the menu for the settings to be saved)
        • Are you sure you flashed Recalbox correctly? Are other settings saved?
        As you are on a PC, if possible, test flashing the system on a pendrive and check if it works, the problem may be a defective hard drive, or a corrupted file.
