    Controllers not working for PSX in RB 7.2.2
    7.2.2
    • lhari84
      lhari84 last edited by lhari84
      Hi,
      I‘ve updated from RB 7.1.1 to 7.2.2. Everything seems to work fine. Also 8bitdo controllers, thanks for that!
      The only issue I have, not any controller works for PSX (PCSX_REARMED), even not the original PS4 Controller. In all other systems, all controllers work fine. What could be the reason?
      Edit: Emulator functions like forward, load, save,… are working, though. Just controlling the games fail.
      Pi 4:
      Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
      Pi Zero 2W:
      GPi Case 2W, Recalbox 9.0
        Zing Global moderator Translator @lhari84 last edited by
        @lhari84 The first thing to do in this case is after the update, after finding the problem, do a factory reset available through advanced settings (you won't lose any personal files like ROMs/BIOS/scrapes/saves, but you will lose all custom settings).
        If that doesn't work, check if none of the PSX games work, or if there are just a few, as some games need special settings, see:
        https://forum.recalbox.com/topic/24428/no-controller-in-psx-games-tomb-raider
        lhari84 1 Reply Last reply Reply Quote 1
        • lhari84
          lhari84 @Zing last edited by
          @zing Factory reset fixed it, thanks!
          Pi 4:
          Pi Zero 2W:
