    No Controller in PSX Games (Tomb Raider)
    Your recalbox
    tomb raider
    2702
    • Tormentor667
      Tormentor667 last edited by
      Dear developers,
      I am having issues with my Recalbox since the last update. Both of my controllers are correctly connected and displayed in EmulationStation. They also work well when playing SNES or NES games but if I try to play the PSX version of Tomb Raider, it tells me that there is no controller connected. I can get back to the EmulationStation with my Hotkey combination though, but I can’t play the game.
      By the way: How can I reset the controller mapping?
      Best regards,
      Torm
      • barbudreadmon
        barbudreadmon @Tormentor667 last edited by
        @tormentor667 see https://forum.recalbox.com/post/169297 maybe ?
        Libretro developper :
        • FBAlpha FBNeo (Arcade)
        • Kronos (Sega Saturn/ST-V)
        • YabaSanshiro (Sega Saturn)
        Tormentor667 2 Replies Last reply Reply Quote 0
        • Tormentor667
          Tormentor667 @barbudreadmon last edited by
          @barbudreadmon no but I was able to fix the problem by setting a different emulator for the game.
          • Tormentor667
            @barbudreadmon something seems to have changed in the recent update though.
            My controllers are working for all various platforms and games, even for some PSX games but for some it doesn’t - it worked before the latest update though.
            The games in question are mostly analog stick games so I guess somethings wrong with the drivers or input settings since the update.
            Can someone investigate this issue any further?
            Pitch64 1 Reply Last reply Reply Quote 0
            • Pitch64
              Pitch64 Staff @Tormentor667 last edited by
              @tormentor667 which core and board are you using?
              Next release? Soon™
              Tormentor667 1 Reply Last reply Reply Quote 0
              • Tormentor667
                Tormentor667 @Pitch64 last edited by
                @pitch64 psx rearmed on a Pi4. On Reddit I read that a few people had exactly the same Problem. They solved it by making a factory reset and that’s what I did - and it works again.
                Still no idea what went wrong.
                • ec
                  ec last edited by
                  Hello,
                  No need to reset anything, just follow these steps :
                  https://retropie.org.uk/forum/topic/29298/non-working-controls-on-updated-ps1-emulator-pcsx-rearmed
                  Don't forget to save the new conf for the whole core to apply settings to all of your games.
                  Did the trick for me.
                  Enjoy !
                  • barbudreadmon
                    barbudreadmon @ec last edited by
                    @ec said in No Controller in PSX Games (Tomb Raider):
                    F0XHOUND 1 Reply Last reply Reply Quote 0
                    • F0XHOUND
                      F0XHOUND @barbudreadmon last edited by
                      @barbudreadmon I had same problem. I changed multitap 1 and 2 options to OFF. Saved as general config and close and start game again. Now works in all games.
