    Wifi
    Your recalbox
    wifi
    2377
    • Marcus1966
      Marcus1966 last edited by
      How to connect with wifi
      Jabba90 1 Reply Last reply Reply Quote 0
      • Jabba90
        Jabba90 @Marcus1966 last edited by
        @marcus1966 network settings, enable wifi, select ssid, enter password, done
        Marcus1966 1 Reply Last reply Reply Quote 0
        • Marcus1966
          Marcus1966 @Jabba90 last edited by
          @jabba90
          Hello
          What do I put in hostname
            OyyoDams Staff @Marcus1966 last edited by
            @marcus1966 what are you doing exactly ? There is no "hostname" parameter in wifi configuration...
            • Marcus1966
              Marcus1966 @OyyoDams last edited by
              @oyyodams
              I just want to go wifi to get some games
                @marcus1966 ok but if you need help please me more explicit about your issue.
                • Marcus1966
                  @OyyoDams
                  i can not connect with wifi
                    Zing Global moderator Translator @Marcus1966 last edited by
                    @marcus1966 - Turn on Recalbox, as soon as it starts you will be in the console selection menu, the "Home" of Emulationstation
                    • Press Start to open the Main Menu
                    • Go to network settings
                    From here there are 2 options:
                    The easier:
                    • On your Modem, press the WPS Button (check on your modem or search the manual, it's not hard to find, but it doesn't stay in the same place on all modems)
                    • Right after that, press the "WPS CONNECTION" button in Recalbox
                      Wait, the connection should happen automatically (provided you didn't take too long between pressing the modem button and the Recalbox button).
                    For those who could not use the WPS connection:
                    • In the "NETWORK NAME" (WIFI SSID), put the name of your Wifi network exactly as it is (ideally there are no spaces or special characters)
                    • In the "WI-FI PASSWORD", enter your WI-FI password
                    • Go to "ENABLE WI-FI" and switch to "ON"
                    If that's not what you want, please describe in detail what you want and why you're not getting it, it's impossible to help you if the most interested - YOU - don't bother to explain so someone can try to help you.
                    Does Your Hardware Have Wi-Fi?
                    What is your hardware?
                    What's your Recalbox version (say the version, don't say "latest")?
                    Did you build your Recalbox yourself, or download a ready-made image from the internet, or buy everything ready-made?
                    • Marcus1966
                      Marcus1966 @Zing last edited by
                      This post is deleted!
