    How to change hotkey combinations in Retroarch
    GamePad/GPIO/USB encoder
    hotkey combinations retroarch
    • Jabba90
      Jabba90 last edited by
      Hey everyone,
      I wanna play N64 games. In order to keep my save files, retroarch needs to be properly closed, otherwise my save games will be deleted.
      For this purpose I need to enter the retroarch menu via a hotkey combination (hotkey + ButtonX).
      I can change (or disable) the hotkey manually using the retroachcustom.cfg and this will be saved. However, if I change the other button for the hotkey combination (eg. ButtonX -> ButtonY) this setting will be overridden when opening retroarch again.
      I'm using the input remap when starting retroarch with the Mupen64Plus_Next core but this shouldn't make a difference right?
      Is there any opportunity to make changes to the hotkeys? I would like to disable every hotkey option except of entering the retroarch menu.
      Btw, I also have a similar issue when I'm trying to use different graphic plugins. These options are also not saved.
      Thanks in advance!
      • Jabba90
        btw, I'm using the current version of recalbox (7.2.1 Reloaded) with a raspberry pi 4b
        clkgames 1 Reply Last reply Reply Quote 0
        • clkgames
          clkgames @Jabba90 last edited by
          @jabba90 you can have a Select+Start combo for entering Retroarch menu for instance.
          To do this, go to /recalbox/share/system/.config/retroarch/config and add the following line for each core configuration file:
          input_menu_toggle_gamepad_combo = "4"
          where "4" is combo Select + Start
          This configuration can be changed while running retroach as well.
          Regards,
          John
          Jabba90 1 Reply Last reply Reply Quote 0
          • Jabba90
            Jabba90 @clkgames last edited by
            @clkgames Awesome thanks!
