    Joystick/buttons signal lost for 2 seconds
    GamePad/GPIO/USB encoder
    joystickbuttons signal lost seconds
    1786
    • Zekelu
      Zekelu last edited by
      Hello,
      I need your help to troubleshoot a quite annoying issue on my bartop.
      My config:
      • Raspberry PI4
      • Kit joystick(Zippy)/buttons with USB encoder card Xinmotek
      • Recalbox version: 7.2.1
      The problem:
      Quite often, it seems the signal is lost between my controls (joystick and buttons) for 2 seconds, and it come back working automatically.
      It seems the last switch pressed is still active for the game, for instance on metal slug, the character is still walking even if I stop pushing the joystick on the right.
      It happens for the 2 players at the same time.
      So I guess it's linked to the USB encoder card...
      My tests:
      • Same issue on differents PI USB ports.
      • Same issue with another USB cable.
      If you have any idea or tests to perform !
      Thank you for you help !
      Zekelu 1 Reply Last reply Reply Quote 0
      • Zekelu
        Zekelu @Zekelu last edited by
        @zekelu said in Joystick/buttons signal lost for 2 seconds:
        Quite often, it seems the signal is lost between my controls (joystick and buttons) and the PI for 2 seconds, and it come back working automatically.
        • Zekelu
          I have just performed a new test :
          • Install an emulator (FBA) on my PC and plug the Xinmotek.
            => It's working without any problem
          So I guess the issue is on the Raspberry side...
          Hard or soft?
          Recalbox config to update?
          Thank you 😊
            Zing Global moderator Translator @Zekelu last edited by
            @zekelu Try a factory reset, and then remap the controls.
            With the factory reset you will lose all personalized settings, but keep your personal files (ROMS / BIOS / SAVES).
            Se a minha resposta foi Ăștil, por favor, dĂȘ um voto positivo, clicando na seta para cima logo abaixo da resposta, ao lado de "citar".
            Zekelu Zing 2 Replies Last reply Reply Quote 0
            • Zekelu
              Zekelu @Zing last edited by
              @zing Thank you for your answer.
              I just reset to factory settings as you suggest, but unfortunately it doesn't help. The issue is still the same.
                @zekelu Well, I haven't seen any similar reports, and I don't have this joystick, so I don't know how to help.
                If you want, you can post a comment on the topic dedicated to version 7.2.1, so that maybe some user will help you:
                https://forum.recalbox.com/topic/24205/recalbox-v7-2-1-commentaires-issues
                OR, if you prefer, you can open an issue:
                https://gitlab.com/recalbox/recalbox/-/issues
                • Zekelu
                  @zing OK thank you, I will open an issue as it's not linked to the v7.2.1.
                  polandluigi 1 Reply Last reply Reply Quote 0
                  • polandluigi
                    polandluigi @Zekelu last edited by
                    @Zing I have the same problem with v 7.2.2. I use 2 pads copies ps3 pad and 8bitdo sn30pro wired. (rpi 4)
                      Zing Global moderator Translator @Zing last edited by
                      @polandluigi
