    Cannot change controller configuration
    GamePad/GPIO/USB encoder
    cannot
    2625
    • Voo2
      Voo2 last edited by
      I have set a wrong configuration for my xbox360 controller (with wireless adapter) by mistake. Now I don't have any possibility to change it again, because my A-Button is set to another button. And I need the A-Button to start the configuration process.
      In which config file can I remove the current configuration? I tried to search , but it was not successful.
        Scavy Global moderator @Voo2 last edited by
        @Voo2 you can also use an other pad or a keyboard to access the pad menu.
        • Voo2
          Voo2 last edited by Voo2
          yes, I have another controller. I'm in the controller menu. But what should I do there? When selecting "configure controller" I have to press and hold A on the controller I want to configure. And this isn't possible for me.
          Therefore I ask for the config file to delete or edit the existing config.
            @Voo2 go in the pad menu with the second pad, then choose configure a pad. And press any button pon the pad you want to configure to access the configuration.
            • Voo2
              Voo2 last edited by
              thanks for your answer. But I already tried that. Pressing any key has no effect. What I noticed is that now I can't configure my second XBox360 controller either. But they both work, because I can steer up and down in the menu.
              What I'm trying to say. My controller has battery, is connected to the receiver and is detected by Recalbox. But the configuration process just doesn't work anymore.
              Scavy 2 Replies Last reply Reply Quote 0
                @voo2 i'm asking to devs.
                  @voo2 Could you try a reset factory ? (a new option in ES menu)
                  • Voo2
                    Voo2 last edited by
                    ah, that's new. I will try this evening. I will inform you then.
                    • Voo2
                      Voo2 last edited by
                      Nice! Everything works again. Thanks for your help. The reset to factory option is helpful!
                        @voo2 Cool ^^
