    Composite not working on 7.2
    composite 7.2
    10
    32
    7833
    • IGA
      IGA @Zing last edited by
      @zing is composite output still not working on 7.2.2?
        Zing Global moderator Translator @IGA last edited by
        @iga If it doesn't work automatically, make the changes suggested above and test, it should work.
        IGA 1 Reply Last reply Reply Quote 0
        • IGA
          IGA @Zing last edited by IGA
          @zing You mean change to dtoverlay=vc4-fkms-v3d ?
          • yes, i've already try it - same effect as above - stuck at splash screen with pacman
          I'm just wondering is this the case for everyone with 7.2.2 ?
          • IGA
            IGA @IGA last edited by
            Ok, i again formatted sd card and install ready image by balenaEtcher.
            And so after change line to dtoverlay=vc4-fkms-v3d in config.cfg the picture is appear. ( this is important information, probably it should be added somewhere in the manual)
            Everybody thanks.
            • edwinsources
              edwinsources last edited by edwinsources
              @vj Bro, with this configuration and editing the part of the dtoverlay = vc4-kms-v3d-pi4 by dtoverlay = vc4-fkms-v3d-pi4 I managed to activate the video jack output, but it stays blocket in the loading screen the ghosts of pacman I found that it only works if I edit the dtoverly and add the line enable_tvout = 1 But it stays blocked, there is, who helps me, Sorry for English I use google translator I speak Spanish
              edwinsources 1 Reply Last reply Reply Quote 0
              • edwinsources
                edwinsources @edwinsources last edited by
                @edwinsources Someone can give me the text of the config and the user config by email edwinsources@gmail.com so I just copy and paste to see if I'm doing something wrong
                  Zing Global moderator Translator @edwinsources last edited by Zing
                  @edwinsources
                  • What is your version of Recalbox (say the version, don't say "latest")?
                  • Did you build your Recalbox yourself, or download a ready-made image from the internet, or did you buy everything ready-made?
                  • What is your hardware?
                  • Are you sure the problem is not the cable? The documentation explains that this can happen with wrong cables.
                  edwinsources Zing 2 Replies Last reply Reply Quote 0
                  • edwinsources
                    edwinsources @Zing last edited by edwinsources
                    @zing recalbox 7.2.2 is the version I install Raspberry pi 4 I use the Raspberry image fot the install
                      Zing Global moderator Translator @Zing last edited by
                      @edwinsources
                      • edwinsources
                        edwinsources @Joey0621 last edited by
                        @joey0621 Bro I have the same error my screen freezes on the same side, did you manage to solve it?
                        • edwinsources
                          @zing I have the correct cable bro
                            @edwinsources Please don't SPAM:
                            • https://forum.recalbox.com/topic/25248/can-not-use-the-composite-output-in-recalbox-7-2-2-on-my-raspberry-pi-4b
                            • https://forum.recalbox.com/topic/25247/no-logro-usar-la-salida-de-video-compuesto-en-recalbox-7-2-2-en-mi-raspberry-pi-4b
                            • Locked by  Zing Zing
                            100.2k
