    RetroArch config not saved
    retroarch config saved
    • AnonymePlayer
      AnonymePlayer last edited by
      Hi,
      i use :
      RecalBox 7.x on pi 4
      Controller : one Xbox 360 and two atari 2600 with adapter
      controller wok great
      While playing an atari 2600 games : in RGUI menu : i set in settings->input->port 1 control the atari 2600 controller : work great.
      In settings->input-hotkeys-menu toggle gamepad combo, i set "select + down" to acces the RGUI with my keyboard, work great.
      But, i can not save that, i have try all the save button, save on exit is on, but this two things is not saved, i have to do the same things everytime i exit the game and launch a new one.
      I have to modify a config file? or something else?
        Zing Global moderator Translator @AnonymePlayer last edited by
        @AnonymePlayer Read this:
        • https://recalbox.gitbook.io/documentation/tutorials/controllers/configuring-custom-buttons/how-to-customize-controller-mapping
        • https://recalbox.gitbook.io/documentation/tutorials/controllers/configuring-custom-buttons/create-a-custom-configuration-by-emulator
        • AnonymePlayer
          Thank you,
          I have add in recalbox.conf :
          stella_libretro.configfile=/recalbox/share/system/configs/retroarch/config/stella_libretro-3.cfg
          No work
          I have try
          stella.configfile=/recalbox/share/system/configs/retroarch/config/stella_libretro-3.cfg
          No work
          she don't save the modification i made on the conf file or she don't load, only work for the session i have modified conf value and when i quit the game i have to do it again next launch.
          any ideas ?
            @AnonymePlayer Read the documentation more patiently, you are confused, notice that the example quotes:
            neogeo.configfile=/recalbox/share/system/configs/retroarch/inputs/neogeo_custom.cfg
            Note that the name of the console folder is used, not the name of the emulator, so in your case it would be:
            atari2600.configfile=/recalbox/share/system/configs/retroarch/config/stella_libretro-3.cfg
            But, maybe this also interests you:
            • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload
            • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload/retroarch-overloads
            • AnonymePlayer
              Thank you again, now it's work :
              To do that : i have rename stella_libretro-3.cfg to .retroarch.cfg (with the dot) and place it in the roms folder (atari2600 in my case) !
              Thank !
