    Odroid Go Advance Super - No Wireless - Recalbox 7.2
    odroid advance wireless recalbox 7.2
    6
    20
    4515
    • junkptb
      junkptb last edited by
      New install of 7.2 does not detect any USB WiFi module. WiFi adapter : TP-Link TL-WN725N. Odroid Go Advance Super.
      Have burnt Batocera to spare SD, booted in same Odroid an using same adapter - wireless works fine. Booted into Recalbox 7.2, nothing. Wired Ethernet works fine. Have also tried updating .conf file, and tried using different SSIDs and keys - no luck.
      WiFi region is UK/GB. Have tried setting to FR, no change.
      Any thoughts? Thanks.
        Scavy Global moderator @junkptb last edited by
        @junkptb try wifi.region=JP
        do you have an other module to test it ?
        • junkptb
          Hi - yes, have tried JP, same issue. Have tried multiple WLAN adapters, same issue :(.
          Have been doing a bit of debugging and it looks to be a driver issue. dmesg shows:
          dmesg |tail -f
          [ 1396.842112] usb 1-1.3: SerialNumber: 00E04C0001
          [ 1396.843573] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
          [ 1396.964602] r8188eu 1-1.3:1.0 wlan1: renamed from wlan0
          [ 1396.973478] udevd[1213]: renamed network interface wlan0 to wlan1
          [ 1397.117191] r8188eu 1-1.3:1.0: Direct firmware load for rtlwifi/rtl8188eufw.bin failed with error -2
          [ 1397.117225] r8188eu 1-1.3:1.0: Firmware rtlwifi/rtl8188eufw.bin not available
          [ 1397.124569] MAC Address = 0c:82:68:26:c8:e3
          [ 1397.150527] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
          [ 1397.284619] usb 1-1.3: USB disconnect, device number 6
          [ 1397.285386] R8188EU: indicate disassoc
          I can't create /rtlwifi to scp the missing .bin file due to the closed nature of the FS.
          Any thoughts? Thanks!
          junkptb 1 Reply Last reply Reply Quote 0
          • junkptb
            junkptb @junkptb last edited by
            @Scavy Sorry - just realised I didn't tag you on my response!
            • davidb2111
              davidb2111 Staff last edited by
              Hi @junkptb
              Looks like wifi firmware are missing.
              I'll create an issue for adding them for next bugfix release.
              Thanks for your report!
              David
              • junkptb
                junkptb @davidb2111 last edited by
                @davidb2111 Hi. Thx for the confirmation. Do we know timelines yet? Seems to be a fairly fundamental omission 🀣🀣🀣. Appreciate your response πŸ™
                davidb2111 2 Replies Last reply Reply Quote 0
                • Pitch64
                  Pitch64 Staff last edited by
                  It depends of all know regressions and our ability to fix them asap πŸ™‚
                  Next release? Soonβ„’
                  • davidb2111
                    davidb2111 Staff @junkptb last edited by
                    @junkptb said in Odroid Go Advance Super - No Wireless - Recalbox 7.2:
                    It should for the end of this week.
                    • davidb2111
                      @junkptb
                      If you are enough adventurous, you can flash or update the beta: see here for details: https://forum.recalbox.com/topic/24142/recalbox-7-2-1-beta3-public-release/52?_=1620043776356
                      David
                      Subzero666 1 Reply Last reply Reply Quote 1
                      • Subzero666
                        Subzero666 @davidb2111 last edited by Subzero666
                        @davidb2111 Hi,
                        I installed the beta but no WiFi.
                        I installed via the update file on the SD card
                        davidb2111 1 Reply Last reply Reply Quote 0
                        • davidb2111
                          davidb2111 Staff @Subzero666 last edited by
                          @subzero666 said in Odroid Go Advance Super - No Wireless - Recalbox 7.2:
                          @davidb2111 Hi,
                          what's the wifi adapter you use?
                          Subzero666 fabriceroux 3 Replies Last reply Reply Quote 0
                          • Subzero666
                            @davidb2111 I bought the TP Link AC600 (archer T2U Nano)
                            • Subzero666
                              @davidb2111 by the way, the Odroid Go Super USB port is ok since a Bluetooth adapter is recognized et the WiFi adapter works on an Odroid XU4Q running Recalbox 7.2
                              • fabriceroux
                                fabriceroux @davidb2111 last edited by
                                @davidb2111 this morning I installed the final 7.2.1 using the offline method on the Odroid Go Super.
                                The TP-Link Archer T2U Nano supposedly using the Realtek RTL8811AU chipset doesn't work. Link to Amazon France.
                                Here are the specs I found about the chipset used in this adapter.
                                I guess I'll order the fugly official Odroid adapter. πŸ™„
                                Subzero666 1 Reply Last reply Reply Quote 0
                                • Subzero666
                                  Subzero666 @fabriceroux last edited by
                                  @fabriceroux hi,
                                  I ordered the official Odroid wireless adapter. If there's no hurry, I'll be able to tell you if it works on 7.2.1
                                  fabriceroux davidb2111 2 Replies Last reply Reply Quote 0
                                  • fabriceroux
                                    fabriceroux @Subzero666 last edited by
                                    @subzero666 nice of you. πŸ‘
                                    I'll try a couple of USB to RJ45 adapters I have in the office. Then I'll probably go ahead and get the Odroid wireless adapter anyway. Not being able to connect via SMB to work on ROM directories is painful.
                                    • davidb2111
                                      Hi @subzero666
                                      Personnaly, I use this one flawlessly:
                                      https://www.amazon.fr/gp/product/B07Y8BMNSG/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1*
                                      fabriceroux 2 Replies Last reply Reply Quote 1
                                      • fabriceroux
                                        @davidb2111 thanks I just placed the order for the Cudy WU650S AC on Amazon France. Delivery is scheduled for tonight. 😁
                                        A wiki page with the supported Wi-Fi chipsets might be useful for the Odroid Go users.
                                        • fabriceroux
                                          @davidb2111 I received the Cudy WU650S wi-fi adapter... it works. \o/ Thanks again. 😁
                                          • Subzero666
                                            @fabriceroux The offical Odroid adapter works fine
                                            Copyright Β© 2021 recalbox.com
