    PSX and N64 doenst work.
    GamePad/GPIO/USB encoder
    doenst work
    1085
    • mushroom
      mushroom last edited by
      Hello there. I'm having some problems with psx games after the update. The controller doesn't work at all and on N64 games, the L and R doenst work too. Anyone having this issue or know how to fix it ? Thanks in advance.
      • mushroom
        Update.
        I think its a problem with the standard/analog/dual shock feature since I can change they on menu but they don't change at all on games.
        Any help ?
        • grendy
          grendy last edited by
          I have the same issue at least with psx. Controller (sn30 pro) works with every other system but with psx controller doesnt do anything. Its all dead...
            Zing Global moderator Translator @mushroom last edited by
            @mushroom Ready this:
            https://forum.recalbox.com/topic/23983/recalbox-7-2-pi-4-resolution-du-probleme-des-manettes-non-reconnues-psx
            @grendy Read this:
            https://forum.recalbox.com/topic/23878/7-2-can-no-longer-pair-8bitdo-sn30-pro-controllers
            mushroom 2 Replies Last reply Reply Quote 0
            • mushroom
              mushroom @Zing last edited by
              @Zing there's a english version somewhere ? Thanks for the help.
              • mushroom
                @Zing thank you !
                  Scavy Global moderator @mushroom last edited by
                  @mushroom Known issues with SN30 pro, SF30 pro and SN30 pro + pads. It concerns firmwares of these pads.
                  Here are the right firmware to use (tested et approved by beta-testers) :
                  Appairing in android mode START + B :
                  SN30 Pro -> firmware v1.33
                  SN30 Pro + -> firmware v4.01
                  SF30 Pro -> firmware v1.33
                  Last firmware updates don't work fine. A fix is in progress.
