    Need help: Main menu sounds start before splash video stops playing!
    need help main sounds start before splash stops playing
    • therealmask
      therealmask last edited by
      Hi all, i need help to figure out a way to change the time of the main menu sound start, because before the splash video stops, the main menu music starts, im not very experient on recalbox, but im a good learning, any help is very welcome and sorry for my bad english, im from brazil! thanks!
        Zing Global moderator Translator @therealmask last edited by
        @therealmask
        If you prefer, there is the Portuguese part of the Forum (although the international part has more active users):
        https://forum.recalbox.com/category/25/português
        You should edit your Recalbox.conf file, as this post says:
        https://forum.recalbox.com/topic/22659/recalbox-7-1-vidéo-intro/4
        Maybe this helps:
        https://recalbox.gitbook.io/documentation/v/portugues/manual-basico/primeiras-nocoes/o-arquivo-recalbox.conf
