    PS4 Dualshock no reconnect after reboot Pi4
    GamePad/GPIO/USB encoder
    ps4 dualshock reconnect reboot pi4
    • svartbart
      svartbart last edited by
      Knock knock, its me, with the next controller-related topic.
      Sorry but I have no luck so far.
      My problem is described like this post from December.
      https://forum.recalbox.com/topic/21901/ps4-controller-not-automatic-pairing-after-boot/4?_=1616701963065
      In short, the BT-Controller is not connecting after rebooting the Pi4 4GB. Version of recalbox is 7.1.1. It is flashed on a SD-Card with 32GB. Image is distributed and flash by Raspberry Pi Imager. The sticker of the Controller I bought is showing CUH-ZCT2E as model-number. I´m quiet sure it not an original one.
      Here some info about the paired and actual connected controller given by bluetoothcli:
      [Wireless Controller]# info 2D:92:30:00:96:C9
      Device 2D:92:30:00:96:C9 (public)
      Name: Wireless Controller
      Alias: Wireless Controller
      Class: 0x00002508
      Icon: input-gaming
      Paired: yes
      Trusted: no
      Blocked: no
      Connected: yes
      LegacyPairing: no
      UUID: Human Interface Device... (00001124-0000-1000-8000-00805f9b34fb)
      UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
      Modalias: usb:v054Cp05C4d0100
      I´m able to force the issue without reboot by turning the BT off and on again by cli command power off/on
      When I try to connect then, the output looks like this:
      [Wireless Controller]# power off
      [CHG] Controller B8:27:EB:FF:08:35 Discoverable: no
      [CHG] Device 2D:92:30:00:96:C9 ServicesResolved: no
      [CHG] Device 2D:92:30:00:96:C9 Connected: no
      Changing power off succeeded
      [CHG] Controller B8:27:EB:FF:08:35 Powered: no
      [CHG] Controller B8:27:EB:FF:08:35 Discovering: no
      [bluetooth]# power on
      Changing power on succeeded
      [CHG] Controller B8:27:EB:FF:08:35 Powered: yes
      [CHG] Device 2D:92:30:00:96:C9 Connected: yes
      First it tells Connected: yes (Controller keeps blinking)
      maybe 3 seconds later => no
      I have testet all options in the recalbox.conf for PS3 controller ( bluez 5 / official / shanwan )
      Am I doing something wrong?
      The post above is closed with the info the issue is fixed with version 7.0.1
      Thanks in advance
      Svart
      Gleber74 1 Reply Last reply Reply Quote 0
      • svartbart
        If it could be caused by BlueZ, is it possible tu update the version manualy to 5.56?
        http://www.bluez.org
          Zing Global moderator Translator @svartbart last edited by
          @svartbart
          I believe that it is not possible.
          Unfortunately I have to agree, you really seem to be unlucky, I researched your problem and there is an open issue, you can comment on it if you want:
          • https://gitlab.com/recalbox/recalbox/-/issues/1309
          • svartbart
            Hey, a small hint for anybody looking analyzing the problem. It seems the issue in reconnecting is a Pi 4 related problem.
            I tried it with a pi zero w and the controller is reconnecting.
            I will also try the 3b+ I´m using for my 3D printer.
            Maybe this will help any developer to solve the problem for Pi 4.
            Happy Estern!
            • Gleber74
              Gleber74 @svartbart last edited by
              @svartbart na tela de configurações de controles coloque primeiro o do PS4 para que tenha prioridade sobre os demais controles. Assim quando reiniciar o sistema não terá esse problema de desconexã
              o.
