    NES Rom running too fast
    nes rom running too
    2188
    • kikone23
      kikone23 last edited by
      Hello, i tried different roms from Super Mario on the NES on my recalbox system with version 7.1.1 and the clock is running too fast ... i really have to run if i dont want to die cause the time is over lol
      i tried roms from europe and japan ... are there any settings that i should consider as well? anyone here that has the same issue?
      thank you alot.
      Kikone23
      Zing paradadf 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @kikone23 last edited by
        @kikone23 Strange, I didn't see any reports from another user ...
        Have you tested with another emulator / core?
          paradadf Staff @kikone23 last edited by
          @kikone23 I believe the counter is made to run faster than seconds, and they programmed that to give that sense of hurry. But if you can't beat the levels because it is really too fast, than that's not normal. Watch some videos and compare.
          • kikone23
            https://www.raspberrypi.org/forums/viewtopic.php?t=62562
            Well, I already found this in the web. Indeed I had a version from JP. And now I replaced it with a european version. But still same issue.
            Regards,
            Christian
              Zing Global moderator Translator @Zing last edited by
              @kikone23
              kikone23 1 Reply Last reply Reply Quote 0
              • kikone23
                kikone23 @Zing last edited by
                @Zing
                On RecalBox? Actually not, because I thought there is only one on this software. Am I wrong?
                  @kikone23
                  On RecalBox?
                  Of course! If it's not in Recalbox, I can't help you.
                  Am I wrong?
                  See for yourself:
                  https://recalbox.gitbook.io/documentation/hardware-compatibility/emulators-compatibility#home-consoles
                  Test with another emulator/core and see if it resolves.
                    @kikone23 imeant something like this:
                    https://gaming.stackexchange.com/questions/356813/how-long-is-a-mario-second-and-is-there-a-reason-why-it-seems-to-be-shorter-th
