    Audio Output via Jack problem
    audio output
    1583
    • legennd48
      legennd48 last edited by
      I had recalbox 7.0.1 on my pc. I got a notification for new update, I noticed that my sound stopped working since the update. The only output option I have is the audio jack.
      I need help fixing it urgently. thank you
        Zing Global moderator Translator @legennd48 last edited by
        @legennd48 Read This:
        https://forum.recalbox.com/topic/21453/recalbox-7-plus-de-son-en-hdmi-pc64
        legennd48 1 Reply Last reply Reply Quote 0
        • legennd48
          legennd48 @Zing last edited by
          @Zing I have been there before. It doesn't help. Thanks
            @legennd48 And this?
            https://forum.recalbox.com/topic/23021/problème-de-son/22
            • legennd48
              @Zing it works! Thanks for the help. You are awesome
              • legennd48
                legennd48 @legennd48 last edited by
                @legennd48 well it worked for a while until I restarted the system, then it stopped working, I had to do this over and over. Is there a way to make it permanent?
                  @legennd48 I'm not sure because I never had this problem, but, try to change it in the recalbox.conf file:
                  audio.device=auto
                  Change it:
                  audio.device=auto
                  For:
                  audio.device=jack
