    Old Smartphone in a retro console
    Community projects
    old smartphone retro console
    • dormidon
      dormidon last edited by
      Hello everybody. I have a old smartphone and I want to install recalbox on it instead of android, if it is possibile. I'm thinking of connecting it to TV via micro usb/hdmi hub. I can connect the gamepad via Bluetooth and for install I can use keyboard and mouse via micro usb hub. If anyone knows how I can do it or knows a tutorial, please write to me. I want to do this because the phone's touch screen doesn't work anymore. Thanks.
        Zing Global moderator Translator @dormidon last edited by
        @dormidon It is not possible, it would be necessary for a developer to modify the entire system, add all the specific drivers for each Smartphone model, adapt each Recalbox feature according to each hardware.
        Think of it this way: not all versions of Android work on all Smartphones, precisely because manufacturers do not allocate a team of developers to do this, because it is a high cost, a lot of work, and a lot of time for that.
        Recalbox developers already have a lot of work for such a small team, there is no intention to do that.
        Compatible devices are those that can download Recalbox here:
        https://download.recalbox.com/
        dormidon 1 Reply Last reply Reply Quote 1
        • dormidon
          dormidon @Zing last edited by
          @Zing Thank you. I'll try to do something else with my old phones. 😊
          • airdream
            Retroarch is enough for a smartphone/tablet.
            You can run lot of systems with it.
