    Order in which the systems appear in the main menu
    Themes & Interface
    order systems appear main
    • MichaelK
      MichaelK last edited by
      Good morning forum!
      I'm trying to customize the Recalbox interface by arranging the order in which the systems appear in the main menu. For this I am editing the file "es_systems.cfg" located in the path /recalbox/share_init/system/.emulationstation/
      The file will have a string of values configuration since it does not work to copy and paste the systems in the order that I want them to appear
      How should I do it?
      Thank you!!!
        Zing Global moderator Translator @MichaelK last edited by
        @MichaelK See this tutorial:
        https://recalbox.gitbook.io/documentation/v/francais/tutoriels/personnalisation-du-frontend/changer-lordre-des-consoles-dans-emulationstation
        If you prefer, I know that ARRM besides scraping games, has an option to change the order of the consoles:
        https://forum.recalbox.com/topic/11850/arrm-another-recalbox-roms-manager/87
        MichaelK 1 Reply Last reply Reply Quote 1
        • MichaelK
          MichaelK @Zing last edited by
          @Zing for some unknown reason I cannot set "favorites" in first position. I have managed to sort all the systems but only "NES" always appears last. Does anyone know why this is and how can I change it?
          Zing 2 Replies Last reply Reply Quote 0
            Zing Global moderator Translator @MichaelK last edited by Zing
            @MichaelK
            yes, if you read the tutorial calmly, at the end of it you are informed that it is not possible to put the favorites first.
              @MichaelK About NES:
              Please make sure that you have not done something wrong, there is supposedly no reason why this system has always been in last position, most likely you have made a wrong configuration (usually a typo, sometimes a space typed incorrectly: interferes and is not so easy to visualize ...).
              See if this link helps you:
              https://forum.recalbox.com/topic/22010/change-order-of-system-ports-not-working-rest-is-working-ok
