    BIOS for PSX
    Emulator Arcade/PC/Console
    bios
    • jakubm82
      jakubm82 last edited by
      Hi,
      I have been looking for a tutorial about BIOS files, where to put them and what BIOS is needed to run PSX1 games.
      I know that most of the games work without BIOS file anyway it's recommended to have one - for compatibility functions and so on.
      I have been able to find this thread: https://forum.recalbox.com/topic/17732/where-do-i-put-the-psx-bios-file/4?_=1610057214896
      and I followed the instructions from the video tutorial.
      I placed SCPH1001.BIN file in /root/BIOS/ folder but it is not detecting it... can you tell why? Any game I ran I am getting message that BIOS file can't be found...
      Best regards
      OldGamesManiac
        paradadf Staff @jakubm82 last edited by
        @jakubm82 I recommend you to just open the main menu and entrr the bios checking. There you'll get all the info you need. The name and the checksum must match.
        jakubm82 1 Reply Last reply Reply Quote 0
        • jakubm82
          jakubm82 @paradadf last edited by
          @paradadf said in BIOS for PSX:
          Thank you! Now all is sorted out 🙂 thanks @paradadf
