    ScummVM - RetroFlag GPi case - d-pad
    7.1.1-reloaded d-pad gpi gpi case scummvm
    • rakeem
      rakeem last edited by acris
      I am running Recalbox 7.1.1-reloaded on the GPi Case and I am having issues getting the D-Pad to function as a mouse in ScummVM.
      There was a similar issue raised in December 2019 and the staff (@paradadf ) mentioned this would be fixed in an upcoming release (6.1.1 I believe).
      The d-pad works fine in the Recalbox UI and all other emulators.
      I have tried switching between the GPi d-pad between hat and direct input mode (select+up and select+left) and also followed suggestions here: https://forum.recalbox.com/topic/19555/scummvm-controls-in-gpi-case of using an updated version of http://controllersconfig.py/
      I tried the one @krnr linked to as well as the one @fleafunk linked to and I am not having any success. Has this issue been reintroduced in 7.1.1?
      • Sebastokrator
        Sebastokrator last edited by
        Unfortunately I have the same issue, can't use ScummVM.
        • ralle211
          ralle211 last edited by
          Has anybody a way to get this work on 7.1.1 ?
