    Recalbox 7.1.1 Nintendo 64 settings
    Emulator Arcade/PC/Console
    recalbox 7.1.1 nintendo settings
    • WSP77
      WSP77 last edited by
      Hi, friends! Thanks in advance for all the good work! Recalbox is just amazing!
      I'm with a problem in Nintendo 64 emulation (Recalbox 7.1.1 running on rapsberry pi 3 +), the games are always on full screen (16:9).
      I would like to put settings on 3:4 with overlay, but I could not change the settings (overlay already installed, I just want to know how to put the resolution in 3:4, to fit the overlay).
      Thanks!
      • airdream
        Maybe your Tv can't handle 4/3 for 480.
        My Pc monitor have same problem.
        WSP77 1 Reply Last reply Reply Quote 1
        • WSP77
          WSP77 @airdream last edited by
          @airdream All the other emulators runs fine and I can change from 16:9 to 4:3 at any moment... It only happens with N64 emulator... Thanks for your answer!
          • airdream
            All emulator run at 720. N64 and DC run at 480.
            Some screens can't do interpolation with aspect ratio on 480. You can force N64 and DC in 720 if you want by editing recalbox.conf file, but rpi3 have not enough power to keep 60fps at this resolution. You have to test, or try to another TV if you prefer keep 480
            • WSP77
              @airdream Hmmm... Thanks, I think i understood... I really would like to play Ocarina of Time again... : /
