    recalbox not work well with DPI LCD on 4B
    recalbox dpi lcd
    9
    54
    15964
    • DRAgon734235
      DRAgon734235 last edited by
      I use a DPI LCD work well at 3B , but when I use the latest recalbox on 4B
      the DPI LCD just can display recalbox logo and stay on that picture
      can not enter Emulator and can not start the game
      the DPI LCD need some configuration at recalbox on 4B ??
      • DRAgon734235
        DRAgon734235 last edited by DRAgon734235
        other question
        I find a problem, recalbox with HDMI LCD on 4B,
        have a problem that the LCD can not rotate 90 degree .
        have some method rotate the LCD on 4B ?
          Zing Global moderator Translator @DRAgon734235 last edited by Zing
          @DRAgon734235
          LCD
          https://recalbox.gitbook.io/documentation/tutorials/video/lcd/connecting-your-recalbox-to-a-dvi-monitor
          rotate the LCD
          https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload/retroarch-overloads#screen-rotation
          DRAgon734235 2 Replies Last reply Reply Quote 0
          • DRAgon734235
            DRAgon734235 @Zing last edited by
            @Zing
            dtoverlay=dpi18
            enable_dpi_lcd=1
            display_default_lcd=1
            #dpi_group=2
            dpi_mode=87
            dpi_output_format=0x7f216
            hdmi_timings=480 0 10 16 59 800 0 15 113 15 0 0 0 60 0 52000000 6
            this is my configuration at config.txt
            stay at recalbox logo not caused by “hdmi_drive=2”
            • DRAgon734235
              @Zing
              if I use HDMI LCD . the same image with HDMI configuration will work well
                @DRAgon734235 I just realized that you are referring to a DPI screen, and I was thinking it was a DVI screen, sorry for the mistake.
                You need to read these tutorials:
                • https://recalbox.gitbook.io/documentation/tutorials/video/display-configuration/complete-guide-on-video-configuration
                • https://recalbox.gitbook.io/documentation/tutorials/video/tft/setting-up-your-small-tft-screen-on-the-dpi-bus
                • https://recalbox.gitbook.io/documentation/tutorials/video/display-configuration/adjusting-the-image-size-using-overscan
                • DRAgon734235
                  @Zing
                  hello, thank for your replay, I think that three wenlink just work for 3B , Not 4B
                  Now I am the 4B DPI problem, at 3B , the DPI LCD display well 。
                  I have tried this weblink
                  https://recalbox.gitbook.io/documentation/tutorials/video/tft/setting-up-your-small-tft-screen-on-the-spi-bus
                  That just work for 3B , not work for 4B ,
                  also tryed this
                  https://recalbox.gitbook.io/documentation/tutorials/video/tft/second-minitft-for-scrapes-and-videos-ogst-case-raspeberry-pi-1-2-3-spi-dpi-small-tft-screens
                  add the code
                  system.secondminitft.enabled=1
                  this code not have any effect
                  This is my problem, the DPI lcd work well at 3B , not work well at 4B
                  your weblink for reference just for 3B not solve 4B problem
                  • ian57
                    ian57 Staff last edited by
                    @DRAgon734235 that's srtrange but it may comes from the Pi4 3D Accel. Try to comment out the 3D acceleration for pi4 to fall back in Pi3-like running.
                    With Pi4 3D accel, only 180° rotation is allowed in framebuffer, 90 and 270 do not work
                    You need to comment
                    #dtoverlay=vc4-kms-v3d
                    in /boot/config.txt
                    After you should able to rotate the display as in your Pi3 config.
                    DRAgon734235 1 Reply Last reply Reply Quote 0
                    • DRAgon734235
                      @Zing
                      DPI LCD same configuration 3B work well
                      But 4B just stay at this recalbox logo image
                      alt text
                      • DRAgon734235
                        DRAgon734235 @ian57 last edited by
                        @ian57 said in recalbox not work well with DPI LCD on 4B:
                        After comment
                        Still stay at recalbox logo image
                        • ian57
                          ian57 Staff @DRAgon734235 last edited by ian57
                          @DRAgon734235 seems that Emulationstation does not like unaccelerated Pi4 config.
                          When I'll have some time will check on my geekworm dpi screen
                          • DRAgon734235
                            geekworm
                            OK ,
                            think you
                            • DRAgon734235
                              @ian57 @Zing
                              have news ?
                              • ian57
                                @DRAgon734235 Hi,
                                It works well... but no rotation 90/270° available from the firmware and the overlay... the fondation doc DOES NOT work!
                                perhaps a lead.. i read something about that the kernel 5.10 supports all rotation from the accelerated overlay... so we need to b*mp to test...
                                As a sum up ... All the screen are working with acceleration but no 90° 270° actually
                                only 180°
                                • DRAgon734235
                                  my 4b stay at this
                                  alt text
                                  Do you have any suggestion ? (Even in “rotate=0” )
                                  • DRAgon734235
                                    @ian57
                                    • ian57
                                      @DRAgon734235 hdmi or dpi ?
                                      which screen ?
                                      • DRAgon734235
                                        @ian57
                                        https://www.aliexpress.com/item/1005001659074233.html?spm=a2g0o.productlist.0.0.9cc286b4PDloaM&algo_pvid=05efcf4a-b64c-4624-b3b0-7450fe193177&algo_expid=05efcf4a-b64c-4624-b3b0-7450fe193177-13&btsid=0b86d81616125235002752171e1e1f&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
                                        Waveshare 2.8inch dpi LCD
                                        • ian57
                                          @DRAgon734235 this screen has 480x640 resolution so you need to rotate it (90 or 270). Actually it seems not to be supported in frambuffer, only with xrandr in GUI. I saw this https://www.raspberrypi.org/documentation/configuration/cmdline-txt.md and tried it but it only works with 0-180° not with 90-270.
                                          • DRAgon734235
                                            @ian57
                                            I do not rotate the LCD with 90 or 270, the LCD display as the default direction like this image
                                            alt text
                                            and the recalbox stay at this picture always
