    Installation stuck at run level 3
    installation stuck run level
    • pirracas77
      pirracas77 last edited by
      hello,
      I'm trying to install 32bit recalbox in a old computer.
      The installation is stuck at "INIT: Entering runlevel: 3" and it seems that there is not going to manage any additional progress.
      Any advice about this point?
      Thanks in advance.
        Zing Global moderator Translator @pirracas77 last edited by
        @pirracas77 Check if any of the suggestions in this topic help you:
        • https://forum.recalbox.com/topic/22462/recalbox-7-0-7-0-1-64-bits-plantage-hp-pavilion-hpe-series
        I believe your problem is related to the LEGACY / UEFI mode, or, it is a problem with grub.
        If it is LEGACY / UEFI mode (safe mode interferes directly with some BIOSes), you need to change this parameter in your BIOS.
        If it is a problem in Grub, it will be changed in the next version of Recalbox: "Grub2 package fix for legacy booting (# 1484)" (See here)
