    [SOFT] MakeCode Arcade games in Recalbox
    Community projects
    arcade games makecode native raspberry pi
    1813
    • Vegz78
      Vegz78 last edited by Vegz78
      Hi,
      Just finished a work-around for running MakeCode Arcade games natively in RetroPie and from the Raspberry Pi OS text console, with keyboard and controller support for up to 2 players:
      https://github.com/Vegz78/McAirpos
      Not sure if this could be of interest here, meaning if it could work with/be integrated in a similar way into Recalbox?
      Br,
      Vegard
      • Vegz78
        Managed today to run MakeCode Arcade games on Recalbox with McAirpos, with menus in EmulationStation and everything.
        Still working on the the last few details:
        -How to keep the game .elf files executable inside the default /recalbox/share/roms/makecode folder
        -Automated installation script for McAirpos on Recalbox
        -Implement and compile a few small changes required for launCharc to detect and work on Recalbox in addition to RetroPie.
        Hopefully back again with good news here soon!
          Hello @Vegz78
          i think you need to go discord channel to ask bkg2k to help you on recalbox because, recalbox use different things to manage gamepads (configgen)
          https://discord.gg/pNjzEt4R
          • Vegz78
            Thanks for the tip, @acris!
            But since the MakeCode Arcade games use raw GPIO inputs or EV_KEY scan codes for controls, the game launcher handles gamepad detection and setup itself, via uinput-mapper and independently of Recalbox/EmulationStation.
            I was positively surprised that almost everything, even the Python parts, worked out of the box on the buildroot system underlying Recalbox. Only had to remove 4 sudo commands from the source code.
            However, there are, as mentioned, still some small details remaining before I can announce a viable solution for MakeCode Arcade on Recalbox, like automated installation and some work-arounds for the overlay mounted file system.
            • Vegz78
              Happy to announce a working solution now!:
              https://github.com/Vegz78/McAirpos#quick-automatic-installation-for-recalbox
              Only for Recalbox 7.1.1-Reloaded! on Raspberry Pi and maybe still experimental, but working on my RPi4 4GB.
              Feedbacks on GitHub are very welcome!
              • Vegz78
                Theme for working McAirpos solution:
                alt text
                • DacK
                  DacK last edited by
                  Wow, impressive ! 😳
                  Vegz78 1 Reply Last reply Reply Quote 1
                  • Vegz78
                    Vegz78 @DacK last edited by
                    Happy to announce Recalbox 8-Electron support for MakeCode Arcade games, with McAirpos!:
                    https://github.com/Vegz78/McAirpos#development-news
                    Here are the first installation scripts:
