    Trouble with network connection after getting new router
    trouble network connection getting router
    2170
    • robotrecords
      robotrecords last edited by
      Disclaimer: I'm not bad with basic networking but I bought this already built to save myself the time so I'm unfamiliar with most aspects of building it (loving it so far though!). When I first connected everything was fine. No issues with the network. I was forced to upgrade to an Altice One router and now my recalbox is having issues. When I connect via WIFI it creates an IP but status is Not Connected. I can see the router sees it. recalbox.local or the IP does not load either. So I ran a LAN cable thinking maybe it was an issue needing an update or I could fix it on the web interface but it still won't work. It loads the online games lobby and my router sees it still. Again recalbox.local and the LAN IP still will not load. recalbox.local:8080/ does load oddly. Googling around hasn't been super helpful. Any ideas? Any help greatly appreciated.
      • robotrecords
        Update: I just talked with my internet provider trying to get it to work and they said it does not appear to be an issue with the router. I find that odd because that's the only thing that changed.
        Zing Paulska 2 Replies Last reply Reply Quote 0
          Zing Global moderator Translator @robotrecords last edited by
          @robotrecords Did you set the Recalbox Wi-Fi IP? If so, that could be it.
          Otherwise, it doesn't seem to be a problem with Recalbox.
          Do a test on another internet if possible.
          Test with a clean installation of Recalbox, without configuring anything, if possible.
          robotrecords 2 Replies Last reply Reply Quote 0
          • Paulska
            Paulska @robotrecords last edited by
            @robotrecords
            so when you connected it with a network cable do you see an ip address in recalbox?
            lobby for netplay works?
            do you know how to login to your router to check if the router gave it an IP address?
            and your only issue is you cant access it through the computer?
            just need a couple more details before people can help you out.
            • robotrecords
              robotrecords @Paulska last edited by robotrecords
              @Paulska With LAN and WIFI I see an IP and I am able to see netplay lobby on LAN but can’t with wifi. My router shows it as connected and I can see the assigned IP. I cannot access it on the computer (besides virtual controller) but also the retropie is saying it is Not Connected despite showing me the IP too. Happy to answer more follow ups. Thanks for your help.
              • robotrecords
                robotrecords @Zing last edited by
                @Zing I did not set the IP but let the network do it.
                • robotrecords
                  @Paulska sorry just tested and Netplay lobby is working on wifi now too
                  • robotrecords
                    @Zing I just tested with another internet and got the exact same results. Creates an IP but listed as 'Not Connected'. Am able to browse Netplay lobby but not able to access recalbox.local on another pc on the same network.
                      @robotrecords What version of Recalbox are you using (say the version, don't say "the latest")?
                      Have you tried to access Recalbox via Windows explorer using IP? Or even via Winscp?
                      Links that may be useful:
                      • https://recalbox.gitbook.io/documentation/v/francais/usage-basique/gestion-des-fichiers
                      • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/systeme/acces/acces-reseau-via-winscp
                      • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/reseau/partage/windows-10-impossible-dacceder-a-recalbox-depuis-le-partage-reseau
                      robotrecords 1 Reply Last reply Reply Quote 1
                      • robotrecords
                        @Zing Thank you for the help. I am on 6.1.1. I am not able to access via browser using the IP either. It also doesn't work from my iPhone (but the controller interface does). I just downloaded Winscp and was able to get access to it however which feels like I am getting closer now to a fix. Any additional help greatly appreciated.
                          @robotrecords
                          I am on 6.1.1
                          Sorry, but the forum does not support outdated versions, you need to be using the latest version if you want support (and, unfortunately, for versions prior to 7.0, it is necessary to do a clean installation).
