    Recalbox 7.01 - 7.11: Update vs new installation?
    recalbox 7.01 7.11 update installation
    • RK.aus.S
      RK.aus.S last edited by
      Hi
      I've just updated my Recalbox from v7.0.1 to v7.1.1 - update worked fine.
      But what I wonder; is an update within a major version (actually 7.x.x) really the same as a new installation from scratch?
      In the release notes of v7.1.0 you can read:
      "... Add 4 MAME games from the '80"
      As expected, I didn't get this 4 MAME games through the update (at least in the MAME folder)? If I would do a fresh install - I would get it.
      Am I wrong? If not; are there even more diffenrences between an update and a new install? Is that described somewhere?
      Thanks a lot - Recalbox is great!
      Regards
      Roman
      ProfMielPops 1 Reply Last reply Reply Quote 0
      • ProfMielPops
        ProfMielPops @RK.aus.S last edited by
        @RK-aus-S Hi,
        There is one difference :
        With the new installation, you add the new games
        • RK.aus.S
          RK.aus.S last edited by RK.aus.S
          Thanks.
          Is there a way to get the "missing" games quick afterwards - without new installation and without searching the ROMs elsewhere?
          • Pitch64
            Pitch64 Staff last edited by
            Next to the /share/directory, there is a /share_init/. Check inside 🙂
            Next release? Soonâ„¢
            • RK.aus.S
              @Pitch64
              Perfect - worked!
              Thanks
