    Gamecube/Wii- What is needed exactly to run?
    Emulator Arcade/PC/Console
    exactly gamecubewii needed run
    12326
    • SkullGrin
      SkullGrin last edited by SkullGrin
      I can emulate these systems on Win10 fine using Dolphin. But i never needed any Bios/plugins/etc to make it happen. I just needed the Dolphin Emu.
      Recalbox however, seems to require a Bios of some type. I've since made like 7-8 attempts to download bios files from various sites. No luck, i can't get anything to run, and i'm stumped at the moment. Exactly what kind of Bios/plugin files do i need exactly and, where should they be placed?
      Any help would be appreciated.
      Beho 1 Reply Last reply Reply Quote 0
      • Beho
        Beho @SkullGrin last edited by
        @SkullGrin hello. You don't need bios... Bios is just to have boot animation . For me Gamecube works perfectly with Recalbox x64...
        PC Intel Q9650 4 go de ram Geforce GTX 670 2Go
        Kit borne arcade de chez Fabrikaborne et déco maison
        Kit 2 joueurs Joysticks + boutons lumineux EG Starts (Amazon) et 2 manettes Xbox One
        Ecran 22p 16/9 full hd
        Recalbox 7.1.1 x64
        SkullGrin 2 Replies Last reply Reply Quote 0
        • SkullGrin
          SkullGrin @Beho last edited by
          @Beho said in Gamecube/Wii- What is needed exactly to run?:
          Thanks. I tried some again, no luck. Just kicks me out back to the main menu. My Gamecube stuff has .ISO extension and Wii, has .wbfs also. My games work great using Win10 Dolphin emulator.
          • SkullGrin
            SkullGrin @Beho last edited by SkullGrin
            Oh, i got it to work now. I didn't do anything besides update Recalbox. Which i already thought i had the latest one but, whatever. I updated when i saw the dialog box pop up.
            The Gamecube and Wii games themselves however, are SLOOOW to start up and SLOOOW to exit back to the menu. When actually running the games appear to be fine but, have lots of occasional "freeze" points. Overall, a buggy experience. Hopefully that's corrected in future updates.
            My Pc uses a Ryzen 5 3400g w/Vega 11 iGPU by the way (and 16GB 2666mhz, Dual-Channel Ram).
            milorqui 1 Reply Last reply Reply Quote 0
            • milorqui
              milorqui @SkullGrin last edited by
              @SkullGrin make sure you have the latest version of recalbox installed
              • SkullGrin
                Found another bug: Gamecube & Wii refuse to load without my gamepad plugged in. Often when adding new stuff and no intent on actually playing anything at the moment? I might not have my gamepad plugged in and just using keyboard instead to test things out. Gamecube & Will? Nope, it auto-kicks me back to the main menu as soon as i select a game. The games only run when a pad is plugged in. I think this is the only system that does that.
                I'm using the 64-bit Pc version of Recalbox also. Not sure if i mentioned that earlier.
