    [RESOLVED] Hide .cue files?
    [resolved] hide cue
    10
    22
    29305
    • ashkeboussi
      ashkeboussi last edited by
      Many of my PS1 roms have both a .bin and a .cue file, each of which is required to make the game run properly. Is there a way I can hide the .cue files? Typically in emulationstation I could hide them in esconfig.xml, but recalbox seems to have its own version of emulationstation.
      • digitaLumberjack
        Hi, just delete it 🙂
        • ashkeboussi
          Don't I need .cue files for my PS1 games to run?
          • digitaLumberjack
            Nope you launch the .bin and it's ok.
            • ashkeboussi
              Certain PS1 games have multiple tracks (some of the Tomb Raider games, among a few others). Is there a way to hide them?
              • ashkeboussi
                Certain PS1 games have multiple tracks (some of the Tomb Raider games, among a few others), so the .cue must be present for it to function properly. Is there a way to hide them?
                • digitaLumberjack
                  So hide .bin by editing /root/.emulationstation/es_systems.cfg by removing .bin from the supported extensions for psone
                  • ashkeboussi
                    Thanks! 🙂 i was looking for that file!
                    • dh04000
                      dh04000 last edited by
                      In 4.0.0, how do I do this now?  (Sorry for necro'ing the thread)
                      • nosfay
                        nosfay last edited by
                        Hi, In 4.0.0, you can hide files directly in ES by using "select" menu on your file and choose "hide" option. (very useful for .cue and bios files 🙂 )
                        • d3m0n1q733rz
                          d3m0n1q733rz last edited by
                          Just make sure that you are hiding only the bin files and that each PS1 games has a cue file with it.  Otherwise, you will have to generate cue files or the game won't show.
                          • arne
                            arne last edited by
                            Hi, is there still a global 'switch' to hide certain file types? Tomb Raider II for example has x61 tracks !! It is very tedious to 'hide' them all individually. Thanks.
                            • loak
                              loak last edited by
                              Hello Arne, Maybe you could download an other file from <del>[Link]</del> Internet. The .zip contains a .cue and a .bin which will be easier to handle. Edit Reivaax : No link to copyright content please. 😉
                              Recalbox last update
                                voljega Banned last edited by
                                Global switch is still there just edit your es_systems.cfg file and remove the unwanted extensions, same as before
                                  Helli In recalbox 4.0.0 Select your game.bin Select button > edit metadata In botton put invisible option > ON
                                  • arne
                                    arne last edited by
                                    Thanks Voljega 🙂
                                    • arne
                                      arne last edited by
                                      Hi, I thought I had this problem sorted out but no. I think the path to the file is /recalbox/share_init/system/.emulationstation/es_systems.cfg But when I try to edit the file I get a "Read-only file system" error. It looks like the game files 'must' be hidden individually unfortunately. Thanks.
                                      • nosfay
                                        Hi, Try this command before editing it : mount -o remount,rw / You also should quit EmulationStation before saving changes or there will be erased: /etc/init.d/S31emulationstation stop Then after save: /etc/init.d/S31emulationstation start
                                        • arne
                                          arne last edited by
                                          Hi nosfay, Yes this works !! Thanks 🙂
                                          • jonjon1977
                                            jonjon1977 last edited by
                                            how would I unhide the cue file if hid it on mistake? I've tried deleting the game and reinstalling it, but it didn't change anything..
