    Solved MAME Beginner - recalbox 7.0.1, Rpi 3b+ - Documentation available?
    Emulator Arcade/PC/Console
    mame beginner recalbox 7.0.1 documentation available
    • fredisback81
      fredisback81 last edited by
      Hi all,
      I am experienced in handling a lot of ROMS except MAME until now and want to dig deeper into arcade gaming.
      The link to MAME documentation is not working / empty, I was looking for a short tutorial into arcade gaming. However, I've read that you need a specific BIOS version for the matching ROM file.
      • Let's say I have a MAME 0.139u1 ROM, where can I get the corresponding BIOS (is there a BIOS collection somewhere)?
      • From what I've read, the MAME BIOS is not downwards compatible, correct?
      • Is there a short tutorial existing somewhere?
      My specs:
      rb 7.0.1, rpi 3b+, ready to go
      That's all for now - thanks a lot!
      Regards,
      Freddy
      RPi 3b+ with Nespi Case - Recalbox v8
        Zing Global moderator Translator @fredisback81 last edited by
        @fredisback81
        BIOS and ROMS are copyrighted, so it is prohibited to solicit or share both on the forum: subject to ban.
        Check the necessary BIOS for each console in the Recalbox itself, open the main menu by pressing Start and enter the BIOS checker (I don't know the correct term in English, but it's not hard to find).
        Unfortunately our tutorials are a little out of date - Recalbox has undergone many changes, and very fast for the tutorials to be updated simultaneously (the team is small, and works for free, due to these limitations, priority has been given to improving the system.)
        Now, it's time for the documentation and tutorials to be improved and updated, one of the improvements is to keep the documentation and tutorials on the same main link.
        With all this change, some tutorials will cease to exist (there are cases where 2 tutorials can be replaced by 1 only), many will be moved (we will have broken links in this transition), and new ones will be created (if necessary).
        Every kind of "makeover" generates a bit of a "mess", and our tutorials are in that time - but it's for a good cause!
        The main language of the Recalbox team is French, automatically, the tutorials are created in French, and only then - when there are willing translators - are they translated into the other languages.
        Check if these links help you:
        https://recalbox.gitbook.io/documentation/v/francais/utilisateur-avance/l-arcade-dans-recalbox
        In addition, there are many unofficial tutorials on the internet and even on youtube, you can search if you are interested.
        • fredisback81
          Hi @Zing
          Thanks a lot for your information!
          I checked the links and I'd say, yes that helps. I switched the emulator in the metadata to MAME2010 / 2015 and then it worked (I think liberto was selected as default and that did not work).
          Thanks also to everyone and of course the french developer team for the amazing work. And yes, if there's translation or technical documentation, or maybe programming needed, I'm happy to contribute in the future.
          Regards,
          fredisback81
