    Rpi4 vs. Rpi3: Performance and emulator quantity changes?
    rpi4 rpi3 performance quantity changes
    • skankster
      skankster last edited by
      Hello.
      With the recent implementation on the Rpi4, I would like to know if there are significant performance on the Rpi4 (specially Dreamcast and PSP) and if the Rpi4 supports other consoles (ex: PS2, Saturn, etc).
      I'm considering to purchase a Rpi4 but if there are no significant advantages, I"ll probably stick with my Rpi3 for a while.
      • Pitch64
        Pitch64 Staff last edited by Pitch64
        Hello, Dreamcast and PSP works fine on rpi4, Saturn is not available on it (~20fps) and as far as i know, there is no PS2 emulator on any system. For Saturn, you should take a look at the Odroid XU4 which run it with better results.
        Next release? Soon™
        SkullGrin 1 Reply Last reply Reply Quote 1
          Scavy Global moderator @skankster last edited by
          @skankster you can also have new arcade systems : atomiswave, naomi and naomigd, improvements concerning N64 cores.
          So, you just have to make up your mind ^^
          • SkullGrin
            SkullGrin @Pitch64 last edited by SkullGrin
            @Pitch64 said in Rpi4 vs. Rpi3: Performance and emulator quantity changes?:
            Somewhat related but, since you bring it up, does the 64-bit Pc version of Recalbox support PS2? That's what i'm setting up right now. So far i know it plays Saturn, Dreamcast, N64, and PSP beautifully (My computer is Ryzen 5/Vega 11 iGPU).
            Edit: I can play PS2 full-speed, and even upscaled to 3x resolution, using PCXS2 emulator. But it would be great if i could have Recalbox running PS2, alongside everything else. Recalbox is my gaming O.S of choice.
            • Pitch64
              There is no PS2 emulator at all yet, for any system.
              Next release? Soon™
