    Solved screenscraper.fr is back to work, but Internal Skraper no - RB 7.0.1 - RPI 3B+
    internal skraper 7.0.1
    8
    16
    5304
    • Space81
      Space81 last edited by
      Hi guys, I finally noticed that the fantastic https://www.screenscraper.fr is back to work, in fact I can do the Skraper from a PC, but not internally in Recabox 7.0.1, why?
      Infinitely thank you for your immense work.
      • AxelR
        AxelR last edited by
        Same here.
        Scrapper fails on my RB 7.0.1
        I thought it was fixed ?
          You need to register user.
          Create account user and edit recalbox.conf
          rollbrett 1 Reply Last reply Reply Quote 0
          • rollbrett
            rollbrett @acris last edited by
            @acris Hi, same problem here.
            I created a account on https://screenscraper.fr/ and edit the recalbox.conf file.
            ### ScreenScraper account
            ;scraper.screenscraper.user=******
            ;scraper.screenscraper.password=*******
            But it wont work for me.
            SUPERPi CASE-J (new) RPi 3b+ Recalbox
            MEGAPi CASE RPi 3b Blast16
            NESPi 4 CASE RPi 4 Recalbox
            GPi CASE RPi Zero 2 W Recalbox
            My RetroArchivments
              you need to delete symbol : ;
              I tried and work for me,
              the servers are overloaded on weekends.
              Scrape your romsets during the week.
              rollbrett Space81 2 Replies Last reply Reply Quote 1
              • rollbrett
                @acris Thank you now it worked.
                My RetroArchivments
                • Space81
                  Space81 @acris last edited by Space81
                  @acris Very tanks without ";" work perfect 🙂
                  • AxelR
                    Works for me too. Thanks a lot !
                    • edubois
                      edubois last edited by
                      I got it to work a few days ago using user and pass, but it crashes very often, if I'm lucky, scraps a couple of hundreads, but eventually I get "Error saving resized image. Out of memory? Disk full?". I still have plenty of gigs on my disk. Running 6.1.1 Dragonblaze on a PI3B+. Is anybody else having this issue? Thanks in advance!
                        acris @edubois last edited by
                        @edubois said in screenscraper.fr is back to work, but Internal Skraper no - RB 7.0.1 - RPI 3B+:
                        no support for 6.1.1, upgrade or user external software like : skraper or arrm.
                        edubois 1 Reply Last reply Reply Quote 0
                        • FoLeY
                          FoLeY last edited by
                          Hey...
                          I can't register on screenscraper.fr..... I never recive a mail from them.... Any solution ?
                          • neo207
                            neo207 last edited by
                            it doesn't work for me, it says scrape finished, completed... but all games are not found... hmm
                            • edubois
                              edubois @FoLeY last edited by
                              @FoLeY emails are no longer sent. I registered and got an account working without the email step. Login with the credentials you registered with, and will work.
                              • edubois
                                edubois @acris last edited by
                                @acris no support because 7.0.1 is out? I tried it, and honestly, I felt performance issues on my 3b+, and some games (like Marvel vs Capcom 2: New Age of Heroes in Neo Geo) stopped working, that's why I went back to 6.1.1.
                                • FoLeY
                                  Thanks edubois... I will give it a try...
                                  • fredisback81
                                    fredisback81 last edited by
                                    Hi all,
                                    same problem here! What I know, screenscraper.fr and its API is blocked for non-registered users up to now.
                                    The hint with the recalbox.conf to add user credentials (from registration at screenscraper.fr) helps a lot in order to call the API as registrated user, which I will try. Thanks!
                                    The status update to the API on screenscraper.fr says:
                                    "The API is closed to all anonymous users (not registered for free on ScreenScraper) for now.
                                    The CPU occupancy rate of the main server seems very high."
                                    I think, that their new setup with loadbalancing still does not work, since CPU1 = 84% and CPU2 = 12%... (ideally it should be 50%/50%) but I don't know their internals.
                                    Regards,
                                    fredisback81
                                    RPi 3b+ with Nespi Case - Recalbox v8
