    Solved Cavestory missing ? (x86_64) v7.01
    Emulator Arcade/PC/Console
    cavestory missing v7.01 x8664
    1532
    • gnubit
      gnubit last edited by gnubit
      Thanks for a great release, I am trying to install cavestory on rb 7.01, but the cavestory folder is missing in the roms directory. I have looked in both recalbox.local/recalbox/share/roms and
      recalbox.local/recalbox/share_init/roms. Has it been moved ? (i do remember it there in rb 6.1x)
      Does this no longer apply for x86_64?
      https://recalbox.gitbook.io/documentation/emulators/portages/cavestory
      Thanks and keep safe.
      jorgemagana 1 Reply Last reply Reply Quote 0
      • jorgemagana
        jorgemagana @gnubit last edited by
        @gnubit it is inside Ports
        gnubit 1 Reply Last reply Reply Quote 1
        • gnubit
          gnubit @jorgemagana last edited by
          @jorgemagana thanks, I looked in the ports folder and its not there, I also copied the cavestory folder to recalbox.local/recalbox/share/roms/ports and it was not seen by emulation station. Any body else has cavestory working on x32_64 with rb ver 7.0.1 ?
          • Jechu2000
            Jechu2000 last edited by
            Pc x86_64 Moi aussi je l'ai pas, je le veut finir!! Il est pas dans les ports.
              Cavestory is not available on X86_x64
              https://recalbox.gitbook.io/documentation/compatibility/emulators-compatibility#port
              gnubit Zeke 2 Replies Last reply Reply Quote 0
              • gnubit
                gnubit @acris last edited by
                @acris thanks for the info, any idea why it was dropped for this architecture ?
                • Zeke
                  Zeke @acris last edited by
                  Bonjour @acris,
                  On sait pourquoi ? Nous l'avions sur la 6.1.1 😢
                  PC x64 MSI X399 SLI Plus
                  AMD Threadripper 1900X
                  64GB Corsair Vengeance 3200Mhz
                  EVGA GeForce GTX 1060 6GB
                  Recalbox sur Western Digital Blue SSD 500Go M.2 (boitier USB-C 3.1 Gen.2)
                  φ(k) ∝ At
                    @Zeke
                    problème de compilation je crois.
