    Can't find and install SFTP addon on kodi
    MediaCenter & Dualboot
    cant find sftp addon kodi
    • zwynyxy
      zwynyxy last edited by
      Hello everybody;
      I have installed the latest version of recalbox (7.01) on my RPI4. everything works fine.
      On kodi, I want to install the SFTP addon to have access to my harddisks connected to another RPI, but i cant find this addon, on addons list.
      Is there any way to intall it manually?
      Thanks in advance for your help.
      Zing 1 Reply Last reply Reply Quote 1
        Zing Global moderator Translator @zwynyxy last edited by
        @zwynyxy check the Kodi website / forum or YouTube, it doesn't seem to be something related to Recalbox.
        • zwynyxy
          Thank You Zing for your reply. i will take a look on the official kodi forum.
          I will keep you informed if any solution.
          phramusca 1 Reply Last reply Reply Quote 0
          • phramusca
            phramusca @zwynyxy last edited by
            Hi @zwynyxy. Have you managed to find a solution ? I have the same problem 😞
            • nobodyfamous
              nobodyfamous last edited by
              I just spent the whole morning trying to figure this out. I don't understand it!!!
              I currently have a LibreELEC (kodi OS) and it lists the VFS add ons. If I install kodi in Ubuntu via the kodi repo, I also can apt-get kodi-vfs-fstp and then it is listed in the add ons. This also works via an Ubuntu based Raspberry pie setup.
              All that said, recalbox has been the best for actuall retro gaming, but I need to be able to add both sftp and a web browser to kodi.
              As I said, this works fine via LibreELEC, but kodi gaming sucks. I have been unable to load the add ons. I found the zip file downloads, but they ALL gave the same error. Somthing about the wrong layout or somthing.
              way down at the bottom, vfs.sftp+... https://mirrors.kodi.tv/addons/leia/
