    extend sd card with usb flash drive possible?
    extend card usb flash possible
    • neo207
      neo207 last edited by
      my sd card is full... can i extend the space with a usb stick or do i have to buy a bigger micro sd card?
      kind regards
      • Pitch64
        Pitch64 Staff last edited by
        I suppose you store all content (roms.etc.) in your sd card.
        The best would be to have all your roms and saves on an external usb stick than having them into your sd card.
        For this, when RB is launched, plug an usb device in and in the settings, choose to use your usb stick. Once restarted, the RB folders structure will be recreated on the usb stick.
        At this moment, you can move the contents of your roms, saves & bios folders into their respectives locations from the sd card to the usb stick 🙂
        Next release? Soonâ„¢
          Zing Global moderator Translator @neo207 last edited by
          @neo207 Just to complement, watch these videos:
          • https://www.youtube.com/watch?v=65deA8c-stM&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=5&ab_channel=Recalbox
          • https://www.youtube.com/watch?v=skeULeTu7p8&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=23&ab_channel=Recalbox
          neo207 1 Reply Last reply Reply Quote 0
          • neo207
            neo207 @Zing last edited by
            @Zing thanks! will try that out with a 2TB external hdd drive
