    Solved Where are the boot videos and splash screens?
    where are boot videos splash screens
    7311
    • A Former User
      A Former User last edited by
      7.0.1 is great, but where are the boot videos and splash screens being stored? In 6.1.1 they were in:
      RECALBOX/recalbox/system/resources/splash
      But this does not exist in 7.0 or 7.0.1. I've searched every directory on all three partitions, and can find no trace of these files.RECALBOX.png
      • ian57
        ian57 Staff last edited by
        @zezuvu here /recalbox/system/resources/splash/ but I think you can put your own vides in /recalbox/share/bootvideos/ to see them.
        A Former User 1 Reply Last reply Reply Quote 0
        • A Former User
          A Former User @ian57 last edited by
          @ian57 As you can see in my screenshot, that directory does not exist. I'm on RPi 4 if that makes a difference.
          • ian57
            ian57 Staff @Guest last edited by
            @zezuvu I think it's in "SHARE" partition
            • A Former User
              It's not in there either.
              • ian57
                @zezuvu at the of your SHARE partition :
                • directory bootvideos
                • directory system (you'll find ressource splash)
                All of this to remove my beautiful videos !
                • A Former User
                  No, I looked there too. Your hiding skills are almost as good as your video skills.
                  • ian57
                    @zezuvu try the OVERLAY partition, the mount system is quite tricky and theses files are only visible on running recalbox because they are stored in the BIG recalbox filen which is a image of the base base system.
                    • A Former User
                      @ian57 OVERLAY is all empty folders and only takes up 73MB.
                      So you're probably right about them being embedded in the RECALBOX/boot/recalbox file.
                      I guess you win for now.
                      • ian57
                        @zezuvu Yes overlay is empty when reading externaly, it is crowded during boot with file system contained in the RECALBOX/boot/recalbox file.
