    boot recallbox 7 from an usb disk
    boot recallbox usb
    937
    • nattyebo
      nattyebo last edited by
      hello,
      i would like to know how to boot from a usb disk (without sd card) with a raspberry 4
      I updated the bootloader but the iso recalbox 7 does not boot
      thx
      • Pitch64
        Pitch64 Staff last edited by
        Hi,
        Recalbox is not available to boot from another hardware than an SD card yet. I don't know if it will be in the future 🙂
        Next release? Soonâ„¢
        • cherrerap
          cherrerap last edited by
          In Rasbperry 3B+ boot from USB memory works fine:
          Find and replace in cmdline.txt file this text:
          dev=/dev/mmcblk0p1
          for
          dev=/dev/sda1
          nattyebo 2 Replies Last reply Reply Quote 1
            Zing Global moderator Translator @nattyebo last edited by
            This post is deleted!
            • nattyebo
              nattyebo @cherrerap last edited by
              @cherrerap ok thx i'm going to try
              • nattyebo
                @cherrerap I tried it and it doesn't work, here is a capture of the bootloader if it can help!IMG_20201021_123113.jpg
