    Dosbox does not work on recalbox 7.0.1
    7.0.1 bosbox does recalbox
    1353
    • dj_cyber2001
      dj_cyber2001 last edited by dj_cyber2001
      as I make dosbox work in recalbox 7.0.1 they no longer recognize .dos or .pc games
      Adrian Nawrocki 1 Reply Last reply Reply Quote 0
        Hello
        I use dos, in recalbox 7.0.1 , rpi3b+, it's work very fine.
        I use Sleep Walker (disket format) + pad2keyboard file + dosbox.bat
        Dos Folder :
        Sleepwalker.pc folder
        dosbox.bat file
        sleep.exe
        Sleepwalker.pc.p2k.cfg file
        # Recalbox's Pad-to-Keyboard configuration
        #Sleepwalker
        #DOSBox
        # original keys
        # Left pour Gauche
        # Right pour Droite
        # Up pour Sauter
        # Down pour Bas
        # M pour Map
        # Space pour Tirer
        # ESC pour Quitter
        # BACKSPACE pour Menu Option
        # ENTER pour Valider/Lancer le jeu
        # dpad to arrow keys
        0:down = Down
        0:right = Right
        0:left = Left
        # Map B to Sauter
        0:b = Up
        # Map Y to Map
        0:y = M
        # Map A to Tirer
        0:a = Space
        # Map Select to Quitter
        0:select = ESC
        # Map R1 to Menu Option
        0:r1 = BACKSPACE
        # Map X to Enter
        0:x = ENTER
        dj_cyber2001 1 Reply Last reply Reply Quote 0
        • Adrian Nawrocki
          Adrian Nawrocki @dj_cyber2001 last edited by
          This post is deleted!
          • dj_cyber2001
            I'll try it how you put it
            • dj_cyber2001
              dj_cyber2001 @acris last edited by
              @acris If it works with the configuration file, another question is there any configuration so that the games do not go too slow
                try to modify in /system/configs/dosbox/dosbox.conf file
                vsync=true to vsync=false
