    X-ARCADE TANKSTICK rasbbery pi4
    GamePad/GPIO/USB encoder
    x-arcade tankstick rasbbery pi4
    6
    27
    5679
    • petros2215
      petros2215 last edited by
      Hello... How to connect x-arcade tankstick in rassperi pi4 Recalbox 7.0.1? Please help me 😞 thanks...
        Hello @petros2215
        on computer, enable joystick configration may be
        In recalbox, enable x-arcade in realbox.conf
        controllers.xarcade.enabled=1
        si not work, please post your archive support.
        and may be @ian57 can help you.
        petros2215 1 Reply Last reply Reply Quote 0
        • petros2215
          petros2215 @acris last edited by
          @acris controllers.xarcade.enabled=1
          No working... Thanks only xbox controller working and keyboard
          • ian57
            ian57 Staff @petros2215 last edited by
            @petros2215 can you send us the support archive to see what"s going on.
            • efisal
              efisal last edited by
              Same issue with X-ARCADE TANKSTICK and Rasberry pi3 B on recalbox 7.0.1
              working good on recalbox 6.1.1.
              and
              setup correctly.
              Any solution?
                Scavy Global moderator @efisal last edited by
                @efisal @petros2215 could you please give a support archive as @ian57 asked for ? He can't help you without any logs, we dont have all devices and matériel. Thanx 😉
                • Vince Pelss
                  Vince Pelss last edited by
                  @ian57 said in X-ARCADE TANKSTICK rasbbery pi4:
                  How does one "can you send us the support archive to see what"s going on."
                  I would love to get this resolved. I updated recalbox on my pi 3, and my x-arcade is no longer recognised....
                  Vince Pelss 1 Reply Last reply Reply Quote 0
                  • Vince Pelss
                    Vince Pelss @Vince Pelss last edited by Vince Pelss
                    @Vince-Pelss If it is on the web interface that says:
                    "If you are asked to send the output of the recalbox-support.sh script, you can do it from here.
                    You'll be given an URL that you'll just have to paste in the forum."
                    It has been spinning for 20 minutes. And I have tried multiple times.
                    How long should it take? I am not sure the recalbox-support.sh script is working.
                    • ian57
                      ian57 Staff @Vince Pelss last edited by
                      @Vince-Pelss there are errors, but an archive is created despite the errors. Juste check
                      Vince Pelss 2 Replies Last reply Reply Quote 0
                      • Vince Pelss
                        Vince Pelss @ian57 last edited by
                        @ian57 When I click 'launch script' it never returns anything.
                        I am assuming there is a file on the \recalbox\share
                        but what is the path to the file?
                        • Vince Pelss
                          OK, is this the folder?
                          \recalbox\share\saves
                          how do I get this file on the forum?
                          • Vince Pelss
                            @ian57 OK, is this the folder?
                            • ian57
                              @Vince-Pelss upload it here simply.
                              • Vince Pelss
                                @ian57 when I drag and drop, it says I have no privileges to do that, and there is no attach document functionality.
                                So as far as I can see, there is no way to upload a zip file here.
                                  @Vince-Pelss
                                  please use server as dl.free.fr or dropbox or google drive.
                                  • Vince Pelss
                                    @acris Thanks.
                                    @ian57
                                    http://dl.free.fr/vyil2xSwZ
                                    Vince Pelss ian57 2 Replies Last reply Reply Quote 0
                                    • Vince Pelss
                                      https://recalbox.gitbook.io/tutorials/access/root-access-via-terminal
                                      terminal access no longer seems to work either.
                                      recalbox 7.1 is pretty much unusable at this point for me (from a fresh install)
                                      Surely I can't be the only one noticing these issues?
                                      • Vince Pelss
                                        @Vince-Pelss headphone jack no longer works with 7.1
                                        • Vince Pelss
                                          @Vince-Pelss it is also interesting to note that the newest pi 3 image has in the cmdline.txt:
                                          dev=/dev/mmcblk0p2
                                          not
                                          root=/dev/mmcblk0p2
                                          so I am not sure if the pi 3 image was tested or if dev=/dev/mmcblk0p2 is meant to work.
                                          I need to change it as I boot from a usb device.
                                          • ian57
                                            @Vince-Pelss please use 7.01 which fix it
