    Official recalbox 4.0.0 beta thread
    Announcements
    beta3 i2c mkarcadejoystic
    108
    356
    357630
    • digitaLumberjack
      This is the official thread for the beta of recalboxOS 4.0.0. Remember to post your issues on github (https://github.com/recalbox/recalbox-os/issues)
      1 Reply Last reply Reply Quote -2
        Good job 😉
          voljega Banned last edited by
          Hi guys I suppose many wiki pages will become obsolete with 4.0.0 (just the new read only system partition will lead to some trouble for custom configuration ?)   Isn't this exactly the right time to start a new, separate wiki with a better wiki system (categorization of pages and automatic tagging of new or recently modified pages woul be great, transparent localiaation too)   Otherwise obsolete pages will keep appearing side to side with the new ones, leading to confusion
          • christopher-barnett
            christopher-barnett last edited by
            Amazing work guys. I'm starting my build now and have a Mame question I see that in 4.0.0 it is using LR-Mame2003 as the default which uses romset version : 0.78 Is there any reason to go for the FBA 0.2.97.37 instead? It's amazing home complex this mame stuff can be. Thanks.
            • lmerckx
              lmerckx last edited by
              Great ... a lot of useful and interesting  new functionalities. Thank you !!! I've just installed it on my "test" SD card and started to have a look. Just a question for now: Is it normal that A and B buttons behavior are inverted (a for back and b for select now) ?
              Recalbox 9.1 on RPI 4, SSD 250Gb, 2 Logitech F710, Nespi4case
              Contributions for DosBox, ScummVM, ResidualVM, Daphne (Hypseus)
              • Lordwars
                Lordwars last edited by
                Bonjour, Je possède des manette NES30, j'arrive à les associé via Bluetooth (je vois la mac adresse, m'affiche manette associé) mais je ne sais pas configurer les boutons dans Emulstation. En usb la manette fonctionne et  avec recalbox 3 beta 17 aussi. Par contre comme dis plus haut par Laurent, le bouton A et B sont inversés dans Emulstation. L'installation m'a donné envie de tester un peu plus la bête  et les nouvelles fonctionalités 🙂
                • bigboo56
                  bigboo56 last edited by
                  Bonjour. Je viens d'essayer de me loguer sur le "module" retro achievement, mais lorsque je veux rentrer mon pseudo, impossible d'entrée une lettre dans le champs prévu. J'ai testé avec un clavier sans fil et un filaire. Même résultat.
                  • steveb83
                    steveb83 last edited by
                    Thank you! I can't wait to try this update. Does it need a fresh install on an SD Card, or should the Auto Update work? At the moment I'm getting a 'No Update Available' message. Thank you again!
                    • th4shin
                      th4shin last edited by
                      En attendant d'avoir une réponse, tu peux modifier le fichier recalbox.conf depuis recalbox manager en tapant l'adresse ip du rpi dans ton navigateur internet.
                      • bigboo56
                        J'ai repassé recalbox en anglais et ça a fonctionné.
                        • jellyjam
                          jellyjam last edited by
                          Comme Steve, je n'ai pas de mise a jour disponible depuis le menu principal ?
                          • denis-boutry
                            denis-boutry last edited by
                            Bonjour à tous. D'abord super boulot cette nouvelle version ! Néanmoins j'ai le même souci que Jérémy mais avec une 8BitDo NES30 Pro en bluetooth. Connexion / appairage ok (mode Normal ou Joystick) mais pas de détection lors de la configuration. En USB ça fonctionne nickel. Si quelqu'un à une piste... Je suis preneur 🙂 Merci !
                              Bravo pour la mise à jour, bon j'ai déjà detecté pas mal de problèmes : - ES est beaucoup plus lent qu'avant dans les menus chez moi - A et B sont inversés dans ES par rapport à avant et deviennent incohérents avec les libellés en bas
                              • daniel-panizo-montano
                                daniel-panizo-montano last edited by
                                So, first of all; congrats for the awesome work made here. The amount of changes from the 3.3/17 is really huge. All the work here is pretty impressive. I have few problems with the version 4.0, one huge and the others... well, not a lot; but quite annoying.  Since looks that the upgrade from 3.3 to 4.0 has to be manual; i made a backup (just in case), format the sd and a clean install of the 4.0. After re-put inside all the games; and all the savegames (a lot of files) in its "/save/especific-system" new location; i realized that some of them doesn't work anymore. 😧 Savestates don't either. (Example, Legend of zelda the minish cap, GBA) The PcengineCD games doesn't work too, with the same files working flawlessly in the 3.3 And, since "thegamedatabase.net" is down and there's a lot of roms to manually scrape; tried to paste my downloaded_images and gamelists folders in the new version, but i can't find it. Where is the location?
                                • 8bit_astronaut
                                  8bit_astronaut last edited by
                                  Hello and thank you for all the efort on your work. Im the administrator of the recalbox sub reddit on Reddit, and people noticed some things that i want to ask you Maybe the question that youll had to answer more times It is normal that in emulationstation A and B buttons are mixed? Next one: a lot of directories changed, how is the method to add individual inputs for each emulator? I tried the old one but doesnt work (im a little noob at this) And finally, how to make save files work? Thank you for your time
                                    @Dragda For scrape : gamelist.xml are now located in roms folder, as the name of the folders are the same you can copy everything from the old gamelist directory to the rom directory (fba libretro seems to cause trouble but it's likely just a name change) images are to be put into /recalbox/share/system/.emulationstation/downloaded_images
                                      • Plus aucun jeu neo geo ne marche dans fba_libretro - ou est passé le fichier es_systems.cfg ? - comment modifier le config.txt pour l'overscan sur la partition en lecture seule ?
                                      • denis-boutry
                                        @Voljega : pour modifier le fichier config.txt contenu dans la partition /boot : mount -o remount,rw /boot Accessoirement que donne une recherche "find -name es_systems.cfg" ?
                                        • jellyjam
                                          Bon bah je sens que je vais attendre finalement avant de faire cette mise à jour ....
                                            @Denis   Merci mais du coup l'activation de l'overscan dans le menu marche quand méme ou pas ?
