    Solved v7.0 Audio problem "audio.device=Default output"
    v7.0 audio output
    • ElFilipe
      ElFilipe last edited by
      Hello,
      Since version 7.0, I have a problem with the sound from a raspberry pi 3 jack.
      On each reboot, the audio settings of 'recalbox.conf' changes.
      the line:
      audio.device=jack
      by
      At this point the audio dont works and I am forced to replace by hand "Default output" by "jack".
      According to the log something is wrong with 'amixer' and access :
      [        7.23] starting new log
      [        7.24] converting dos to unix carriage return characters
      [        7.30] setting keyboard layout to fr
      [        7.30] setting audio volume to 90
      [        7.31] setting timezone to Europe/Paris
      [        7.31] setting hostname to RECALBOX
      [        7.33] enabling mk_arcade_joystick_rpi
      [        7.35] ---- recalbox-config.sh ----
      [        7.36] ---- recalbox-config.sh ----
      [        7.38] setting audio volume : 90
      [        7.38] rmmod: can't unload module 'mk_arcade_joystick_rpi': No such file or directory
      [        7.33] Simple mixer control 'PCM',0
      [        7.33]   Capabilities: pvolume pvolume-joined pswitch pswitch-joined
      [        7.33]   Playback channels: Mono
      [        7.33]   Limits: Playback -10239 - 400
      [        7.33]   Mono: Playback -662 [90%] [-6.62dB] [on]
      [        7.39]
      [        7.40] : loading module mk_arcade_joystick_rpi args = map=1,2
      [        7.46] Setting volume for numid=3
      [        7.48] Setting volume for numid=2
      [        7.49] Setting volume for numid=1
      [        7.51] Setting volume for numid=5
      [        7.33] amixer: Control default element write error: Operation not permitted
      [        7.33]
      [        7.52] Setting volume for numid=4
      [        7.55] Force unmute on HDMI
      [        7.33]
      [        7.56] Force unmute on HDMI
      [        7.58] Restoring audio configuration
      [        7.60] setting audio to Default output
      [        7.62] ---- recalbox-config.sh ----
      [        7.64] Unknown audio format : Default
      [       15.66] starting xarcade2jstick
      [       16.25] xarcade2jstick : no official stick found, looking for keyboard encoder now ...
      [       17.79] starting emulationstation with lang = fr_FR
      [       17.84] emulationstation-starter started
      [       17.85] started emulationstation (pid=917)
      [       17.91] S32mini TFT : Reading system.secondminitft.enabled => 0
      [       17.94] S32miniTFT not enabled
      [       17.97] ---- recalbox-config.sh ----
      [       19.17] Starting S92switch
      [       19.17] script /recalbox/scripts/powerswitch.sh [ STARTED ]
      [       19.29] Starting S94manager
      [       19.30] ... Starting manager v2
      [       65.04] ---- recalbox-config.sh ----
      [       65.11] recalbox.conf saved to /boot partition
      [      184.20] Stopping S94manager
      [      184.34] Stopping S92switch
      [      184.35] script /recalbox/scripts/powerswitch.sh already stopped !
      [      184.36] emulationstation exited code 0
      [      184.37] emulationstation-starter ended
      [      184.66] S32mini TFT : Reading system.secondminitft.enabled => 0
      [      184.68] S32miniTFT not enabled
      [      184.79] Stopping Emulationstation
      [      185.01] Stopping S13fbcp
      [      185.10] recalbox.conf saved to /boot partition
      Best regards
      • ian57
        ian57 Staff @ElFilipe last edited by
        @ElFilipe This bug has been reported an is fixed on 7.01 with comes tomorrow... be patient 😄 until there
        ElFilipe leroms77 2 Replies Last reply Reply Quote 0
        • ElFilipe
          ElFilipe @ian57 last edited by
          @ian57 Merci beaucoup !
          • leroms77
            leroms77 @ian57 last edited by
            @ian57 hello there 😉
            i am using latest version 7.0.1...And still the issue with audio.device=Default output
            Do you have any clues ?
            leroms77 1 Reply Last reply Reply Quote 0
            • leroms77
              leroms77 @leroms77 last edited by
              @leroms77 said in v7.0 Audio problem "audio.device=Default output":
              PS: I have used recalbox-config.sh audio and it worked 🙂
