    SCUMMVM RB 7 - GPIO Problems ?
    scummvm gpio
    962
    • Space81
      Space81 last edited by
      Hi, I noticed a bug on scummVm in RB 7, in the previous version 6.1.1, with rpi 3b + and GPIO commands I was able to move the mouse pointer easily without using the keyboard, now not anymore ๐Ÿ˜ž can you help me?
      Thank you.
      • Space81
        Iโ€™ve update 7.0.1 but the problem remains ๐Ÿ˜ž
        • ian57
          ian57 Staff @Space81 last edited by ian57
          @Space81 seems to be a retroarch issue/config, not a gpio problem, you ca try to confugure the retroarch core through its interface during game to emulate analog device with keys
          Space81 1 Reply Last reply Reply Quote 0
          • Space81
            Space81 @ian57 last edited by Space81
            @ian57 thanks but because in the 6.1.1 RB it work very well in automatic ? Excuse the my ignorance, how should I do it ?
            Consider that in my bartop, I don't have the hotkey key button and to quit the games I rely on a python script that is activated when the โ€œstartโ€ key is pressed for 3 seconds.
            Thank you very much.
            • ian57
              @Space81 retroarch has been heavily b*mped with 7.0, with lots of changes. I think you sould plug a standard game pad and configure it to get HK to be able to run retroarch menu.
              • Space81
                @ian57 Very thanks ian ๐Ÿ™‚
                I'll try with a usb keyboard, do you know what are the keys to enter the retroarch menu with this device?
                • ian57
                  @Space81 F1 key see https://docs.libretro.com/guides/navigating/ and https://docs.libretro.com/guides/input-and-controls/#default-retroarch-keyboard-bindings
                  • Space81
                    @ian57 thank you for your helpfulness and kindness !
                    Copyright ยฉ 2021 recalbox.com
